Unknown Noise from Heatercore Location
Hey guys (and gals)
I have had this problem since about mid summer, and Im just now getting time to investigate it at it was not serious.
I have a sound, I dont know how to describe it, but almost like a pump sound, it lasts for 1-3 seconds and happens when I have EITHER the heater or the a/c on. it happens every few minutes, seems to be random intervals. I thought it might be the fan, but retracted that thought when I out the ignition in the "Run" (without the engin running) postion to run the fan, and the noise didnt apear. When I have the climate control to "Off" it dosnt happen at all.
I have NO leaking, nothing on the floor, no vapor on the window, and no sweet smell of coolant. So I belive my heatercore is alright, besides, it also happens when A/C is on too?
Although, I do have a light smell of mold that occurs when I engage the climate control, and lasts about 30 seconds, I believe these are unrelated problems though.
Anyone have some Insite?
Yes...the coolant is running through the heater core constantly. Even more so when the heater is on obviously, but also, more with the AC running. The engine then has a load on it, running a bit hotter, so the coolant is moving even more. Air in the system is really common but annoying. "Burping" the system would be the best first step, and of course the cheapest. Just throw your truck over your shoulder and start patting....
Remove the cap to the radiator and the resivoir and run the truck til it gets hot. As the fluid is exchanged around, you will see some bubbles rising. As you do, add more fluid first to the radiator til full, then to the resivoir if needed.
I had thought that the colant ran through the heater core all the time, which would account for the noise.. but the thing that still has me questioned is, when I have the climate control in the off position, I dont hear anything. Regardless, I will blead the sytstem this weekend. I will let everyone know, thanks guys for your insight
Well, an update:
I did top off the colant, although it really wasnt that low below the line, and then drove it to work this morning, giving it a chance to cycle, and well, no luck. Infact, i noticed thismorning it seems to be increasing the occurance. The noise in question happens almost every 30seconds -1min, and as a result, I just turn the stereo up louder.
What is the blend motor, and can I get at it without ripping the dash apart?
The blend motor is a white box approximately 4" square and approximately 3/8" thick. There is also a metal lever that connects to the blend flap lever. It is located on the evaperator box. Should be able to get to it with out tearing the dash apart. I saw the same problem on a Taurus I worked on. I have not had the problem on my truck yet. I hope this helps.
fixit5561
08-07-2010 08:14 AM
LongRider
06-20-2010 09:37 PM
frigerator
13
09-11-2009 07:16 PM
