roller rockers ? - Ford Truck Enthusiasts Forums
roller rockers ?
Old 10-09-2005, 02:40 AM
papa's 64 papa's 64 is offline
papa's 64 is starting off with a positive reputation.
roller rockers ?
I know the y block has solid lifters but can you get roller rocker arms for the y. What other high performance parts are out there im looking to totally rebuild my 292 when i come back from Iraq. I'm planning on putting about 8 grand total in my 64 step side. I want to keep it mostly original but with some upgrades to the motor.
Old 10-09-2005, 03:20 AM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
Roller rockers, aluminum, are available from Rocker Arm Specialties. Also look at www.ford-y-block.com for other performance items. Aluminum 4v intake, aluminum flywheel, increase your intake valve size, and even stroke the motor. The problem is dollars. You could probably put the biggest portion of the 8K in the motor alone. So pick and choose.
Come home safe.
Old 10-09-2005, 06:28 AM
Spiker's Avatar
Spiker Spiker is offline
Spiker is starting off with a positive reputation.
Talking That's nice, upgrading your 64 Y.
We are great fans of the 292 Y-block! Just take a look at our site http://www.fordfront.nl, so you can see for yourself how big of a fan we are. It's nice to know that your want to spend that much money on upgrading and restoring your Ford, just like we did. We wish you lots of pleasure doing so, come back safe.
Old 10-09-2005, 11:56 AM
46yblock's Avatar
Old 10-09-2005, 01:53 PM
spiker just want to say that's one great looking truck. thats my truck but mines blue with the white top. I've been to ur web site before. I have your f100 on my desktop background. That's what a ford should look like.
Old 10-10-2005, 12:20 AM
pcmenten pcmenten is offline
pcmenten is starting off with a positive reputation.
We've hashed this subject ad nauseam. Try doing a search.
Zero-deck the pistons. Install Mummert's 1.84" intake valves. Get a 312 cam or similar. Get a ECZ-B iron intake, and a Holley, Edelbrock, Autolite or similar carb. Buy a new distributor from AutoZone.
Old 10-10-2005, 12:23 AM
pcmenten im not sure if u are trying to be a smart axx or not i sure hope not, but thanx for the advice on valves and stuff. maybe im just reading u wrong.
Old 10-10-2005, 12:40 AM
Not so much a smart-*** as trying to encourage forum members to perform due diligence prior to posting. We don't mind discussing performance tuning, but we'd rather not plow the same ground over and over.
Again, I'd encourage you to do a search because there's more to learn from other people's posts.
BTW, what transmission do you have?
Old 10-10-2005, 02:03 PM
It's got a 3spd in it. I plane on keeping it that way. I'm gonna keep it as original as possible with a few performance upgrades.
Old 10-11-2005, 11:51 AM
Spiker's Avatar
In reaction to papa's 64 message from 10-09-2005 12.53 PM:
Thanx very much.
Old 10-11-2005, 09:17 PM
Quote:
I hear what you're saying about originality. I'd be sure to stay real mild with the cam. With that 3sp transmission, you'll want to preserve the low-end torque. Those heads are very closed-chamber designs and they'll respond to the zero-deck technique.
Roller rocker question brandon mauldin Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 09-07-2014 12:04 AM
Is there a cheap rocker arm upgrade for EFI trucks? cjsteak Ford Inline Six, 200, 250, 4.9L / 300 9 01-24-2011 03:32 PM
351 HP gains? and heads bigrapp45 1978 - 1996 Big Bronco 8 10-11-2008 06:12 PM
Long Term Storage Recomenditions ??? JORYLEE76 6.0L Power Stroke Diesel 24 04-11-2007 09:50 PM
assessories for my '04 mtboys84 Escape & Escape Hybrid 8 12-11-2004 10:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
