Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Appearance & Dress-Up SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-09-2005, 12:25 AM
guthrie&co's Avatar
guthrie&co guthrie&co is offline
guthrie&co has a good reputation on FTE. guthrie&co has a good reputation on FTE.
shampoo seats and carpet
So i rented the rud doctor from the g store and spent all day cleaning the seats and carpet. it came really clean but since i am so picky it wasnt clean enough. and didnt smell like i wanted it to. it seems like every truck i own always has some funk smell in the cab. it gets cleaned and no bottles food etc left in it. although i might let a fart in the seats every once in a while. the truck kinda smells musty. i want the clean fresh air smell and i dont knwo what else to do to get it that way. i havent taken the carpet out yet nor the seats. if i did take the carpet out could u have if dri cleaned? so wht does it take to really get the interior clean?
__________________
Daniel
I come in peace. I didn't bring artillery. But I'm pleading with you, with tears in my eyes: If you screw with me, I'll kill you all." ~ Marine General James Mattis to Iraqi tribal leaders
  #2 (permalink)
Old 10-09-2005, 06:47 PM
triton_2002's Avatar
triton_2002 triton_2002 is offline
triton_2002 is starting off with a positive reputation.
You can put a couple of dryer sheets under the seats
__________________
2002 F-150 Supercab 5.4 Triton V8
Arizona Biege
  #3 (permalink)
Old 11-19-2005, 06:54 PM
berkad's Avatar
berkad berkad is offline
Strange days indeed
berkad has a good reputation on FTE. berkad has a good reputation on FTE. berkad has a good reputation on FTE.
Every couple of years I replace the carpeting and if you are like me,,,,,,,, your farts should smell like roses.
__________________
Begin, the rest is easy!
Life is a spiral! Your direction is your choice!
Steve
  #4 (permalink)
Old 11-20-2005, 06:41 PM
Patatoe1's Avatar
Patatoe1 Patatoe1 is offline
Patatoe1 is starting off with a positive reputation.
How hard is it to remove the carpeting and reinstall the carpeting?
I also have the musty smell in my truck, but since I am the second owner, I don't really know what the first guy did to cause the smell.
  #5 (permalink)
Old 11-20-2005, 07:05 PM
Gotta take out the seats and maybe the seatbelts.
__________________
Arizona Biege
  #6 (permalink)
Old 11-20-2005, 09:20 PM
Brian0445 Brian0445 is offline
Brian0445 is starting off with a positive reputation.
before you shampooed the carpet were there any appearent wet spots? Could be that sometime someone left a window open when it rained and the seat(s)/carpet got wet which is causing the smell? The cabs on the superduties are pretty watertight (at least on mine).... I know the cleaner that you use in the shampooers can make a difference. From past experience try to use very little soap because the soap attracts the dirt! I havent smelled any funky smells in my truck, but i use air vent freshners, and i clean my air vents out with a small vac, and air compressor air.
  #7 (permalink)
Old 11-20-2005, 10:10 PM
Patatoe1's Avatar
How exactly do you clean cloth seats with a shampooer? If it was rain that is causing the smell in my cab wouldn't the rain have soaked deep into the seats. And how deep would the shampooer be able to clean? Would it be better to wait until the spring time too to do this, so that it would be warmer and more of the water from the shampooer would be able to be dried up quicker instead of just kind of sitting there.
How exactly do you clean out your vents?
Does anyone know how much it would cost to say just replace the carpeting inside the cab?
Thanks again for all the help/input/advice.
James
  #8 (permalink)
Old 03-02-2006, 09:41 PM
The Blue Pearl's Avatar
The Blue Pearl The Blue Pearl is offline
The Blue Pearl is starting off with a positive reputation.
Vents Q tips and small tooth brush
__________________
Never Trust a Blonde Pirate in a Ford 250, 7.3 Turbo Diesel Called The Blue Pearl. Savvy!
  #9 (permalink)
Old 03-03-2006, 05:44 AM
NorthPac's Avatar
NorthPac NorthPac is offline
NorthPac is starting off with a positive reputation.
First I would vacuum the rugs & seats “real good” /w a strong vacuum because that is vary important then do a carpet extraction. One thing you don’t want to do is use lots of water because you want the rugs to dry out real quick if not then mold can develop which smells and is toxic.
Ozone machines are real good for getting smells out of cars. It takes about a day to do this
  #10 (permalink)
Old 03-03-2006, 08:23 AM
TN-W124 Diesel's Avatar
TN-W124 Diesel TN-W124 Diesel is offline
TN-W124 Diesel is starting off with a positive reputation.
try frebreeze, at your local walmart
__________________
2000 F250 SC 7.3 PSD, 4x4, auto, 3.73, AIS (SOLD)
Mobil 1 Oil & Filter W15-50
17 to 19 MPG with
RED LINE® Diesel Fuel Additives
2006 Mazda Tribute 6cy 21 to 25 MPG (wife's)
  #11 (permalink)
Old 03-03-2006, 09:21 AM
NorthPac's Avatar
frebreeze is good stuff but it's best to remove the course of the odors then to hide odors.
  #12 (permalink)
Old 03-04-2006, 02:37 PM
furball69's Avatar
furball69 furball69 is offline
furball69 has a very good reputation on FTE. furball69 has a very good reputation on FTE. furball69 has a very good reputation on FTE.
There doesn't necessarily have to be a noticeable wet spot ON the carpet for there to be water underneath them, as I have noticed. While running wires from the HU to an amp, I pulled up the carpet on the front passenger side and it is wet, apparently it is common with my truck; I never noticed a musty odor, however, until I pulled up the carpet.
It is definitely best to do this on a hot day, so everything can dry promptly. The carpets don't need to be drycleaned but you can take them to a carpet cleaning place that has an onsite facility and they will clean them with an upholstery tool; one advantage is that they will have disinfectants/odor neutralizers they can spray on it.
Those 'tree' air fresheners work. I've smoked cigars in my truck, every day, for over a year and it does not smell like smoke in it, keep using some form of air freshener and replace it every week or two, it will eventually smell better, barring an underlying cause that hasn't been fixed.
__________________
Who is Ron Paul
"It's not the votes that count, it's who counts the votes"
I can't outrun bullets, but I might outrun an *alien* with an empty gun.
My fuel economy calculators
  #13 (permalink)
Old 03-04-2006, 06:52 PM
tdister's Avatar
tdister tdister is offline
tdister is gaining momentum as a positive member of FTE. tdister is gaining momentum as a positive member of FTE.
One thing I do to keep the truck smelling nice is use Ozium air freshener. Have the engine warm and turn on the A/C to recirculate with the heat all the way up and the fan on high. Now spray a liberal dose of ozium throughout, makeing sure you spray it under the dash also so it gets in the vent. system. Close it up and let it run for 10-15 min. (don't sit inside while doing this ) Turn it off, close it back up and let it sit as long as possible, preferably in the sun. Then air it out a little.
Dryer sheets or a good smelling bar of soap work well as a constant source. When the soap stops smelling good, take it out use it to shower to get off the outside layer off, let it dry and put it back.
DO you notice it more right when you get in or more after you turn on the A/C /vent.?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
