I don't plan on following up with this post with much more data, so please take it for what you think it's worth; I simply want to put it out there to save people some possible future headaches. Please don't be offended if you reply to this thread and I either avoid or simply don't reply to a question.
To any users of aftermarket flash programmers- If returning vehicle to stock for warranty/service repairs or diagnostics, I strongly recommend disconnecting the battery cables in conjunction with flashing the truck back to stock calibration. The Motorola MPC555 Processor contains 2 types of memory- FEEPROM and SRAM. Not all "freeze frame" and self-adaptive learning code is cleared from processor memory by reflashing the FEEPROM alone; disconnecting the battery terminals either directly before or directly after the return-to-stock flash will TOTALLY ERASE ALL PROCESSOR INFORMATION.
This applies for any performance device which loads via the under-dash Data Link Connector (in other terms, OBD-II port)
The reason for the wait is due to the capacitors in the PCM discharging. If you disconnect the negative battery cable, and short it to the positive battery terminal, this should discharge these capacitors immediately.
__________________
1921 Ford Model T
1961 Ford Galaxie
1972 Volvo 1800E
1981 Mercedes 300D
1993 Mercedes 190E 2.6
1999 Ford Ranger 3.0L FFV 2WD
Photo Site: photos
Good idea.
These processors do not have the ability to write to thier own flash memory (and don't have allocated memory blocks to do so, even if they did), and have no "hard" method of storing data elsewhere (ie, hard drive, ect). Doing both the flash back to stock and clearing the KAM (SRAM) results in 100% erasure.
You can then procede to bending over as Ford's claims authorization officials pucker their lips (Unless you did something incredibly dumb along the way)
Hey Matt,
I don't know for sure, but I believe the processor is writing the FLASH device when an update is done. I don't think the FLASH device is accessible directly from the OBD-II connector.......
__________________
1921 Ford Model T
1961 Ford Galaxie
1972 Volvo 1800E
1981 Mercedes 300D
Photo Site: photos
The erase of the flash is done directly through the data link connector, via a simple power pulse signal...As for the actual rewrite, you are correct, because the data is transferred over the SCP and CAN networks...so you are most certainly correct, there isn't a direct link.
I worded that last post a little funny and it did sound that way. What I meant to say was that the processor doesn't have any of the algorithms needed to transfer and store input data from sensors onto a memory block, and doesn't have a memory block allocated to store them even if it did. Hence the need for the "black box" plug-in datalogger Ford uses for diagnosis on troublesome trucks.
It would be in educated speculation that this will change next model year. But thats OK, because if it is written there is always some way to erase it
Don't forget, we have TWO (2) batteries. Both must be disconnected....Do NOT touch cables together with only ONE (1) battery disconnected. You WILL get lots of sparks!!!
__________________
BPofMD - Bud
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB CrewCab Arizona Beige
2007 Arctic Fox 30' Fifth Wheel - 1997 Lincoln Mark VIII LSC
Very good point!!!!!
__________________
1921 Ford Model T
1961 Ford Galaxie
1972 Volvo 1800E
1981 Mercedes 300D
Photo Site: photos
Removing the battery cables and shorting them together is also stronlgy recommended prior to any arc welding on the vehicle. This eliminates any path for eddy currents/ground loops to send current where it shouldn't go....
So I guess Im reading this wrong, do you mean touch the two disconnected cables together? not touching the neg cable to the positive terminal on the BATTERY???
