Small Hint For Flash Programmer Users
So as I read this thread, trying to summ it up, the process would be:
1) flash truck back to stock
2) turn on the headlights
3) disconnect both batteries
4) short out + to - cable on both batteries,
5) leave truck sit like this for 3-5min
6) connect everything back up
7) take truck to Ford for whatever work inspired doing this
That about summ it up?
2) turn on the headlights Not needed
4) short out + to - cable on both batteries Only needed on 1 battery,
5) leave truck sit like this for 3-5min Not needed
I have not looked at the wiring specs so am guessing when you say I don't need to short out both batteries that means they run more in parallel then in series? IThinking as I type I guess that makes sense as we don't run our trucks at 24 volts ... do we? (pardon the newbie-ness as this is my first diesel)
Bob, I do hope you're not suggesting paralleling the clamps on one battery only while the other is still attached? I think it might be prudent to insert a giant warning that this should only be done AFTER BOTH BATTERIES HAVE BEEN DISCONNECTED.
Unless you like letting the magic smoke out (and, believe me, they pack a *lot* of smoke in dem batteries!)
#29
Nitpick: Data is not stored in a capacitor. A capacitor stores charge... which keeps part of the memory "alive" (refreshing) thus potentially storing data. </pedant>
#30
Originally Posted by coogan1
What if truck was flashed back to stock 6 months ago? I had the Predator, took it out, and put truck back to stock. I never disconnected batts, etc. Does that mean evidence is still there in the pcm capacitors? If I disconnect batts., etc. now will that clear everything?
