Knocking at start up
I have a 5.4 motor in my F250 with 78000 miles on the clock and still under a power train warnety.
After the truck sit for a day next time I start it it has a knock in the motor do you think ford will fix this or just give me the run around and the song and dance show or will they fix this.
Or, you CAN take it to Ford and hear what they have to say, while you suggest they look at the mass air flow sensor. See if they'll fix it under warranty...
Good luck,
Daryl
well the knock you are describing is not electrical related. it is from the anti drain back valve in the oil filter. this is a problem. that is why the oil filters these use are special. the motorcraft filter has a silicone valve to seal . the aftermarket ones like fram and others that use the regular black rubber leak and allow the filter to drain back into the pan. so the noise is the engine starving of oil on startup. use the correct filter and see what happens.
Brooce_AZ
Modular V10 (6.8l)
16
12-16-2013 10:45 PM
