03 f550 4x4 conversion - Ford Truck Enthusiasts Forums
Old 10-08-2005, 06:53 AM
dano550 dano550 is offline
dano550 is starting off with a positive reputation.
whats up guys new to the forum.
i have a 03 f550 2wd i want to convert it to 4x4 anybody been down that road?
thanks dano
Old 10-08-2005, 07:56 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 10-08-2005, 08:13 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
thanks dano
Welcome to the forum dano550. I've never tried to upgrade a truck like that before. I do know that for the 450 - 500 series that everything is bigger. Ball joints for instance. So you'll have to find the correct front axle and driveline. If you try and stick the 250 - 350 axle in the front it will be overloaded. The transfer case is the same, I believe. It shouldn't be too hard of a job. Just some very heavy parts. You'll need a couple of floor jacks, buddys, and cases of beer to keep them around.
Have you checked any wrecking yards for the necessary parts?
Old 10-08-2005, 09:09 AM
1997F-350's Avatar
1997F-350 1997F-350 is offline
1997F-350 is gaining momentum as a positive member of FTE.1997F-350 is gaining momentum as a positive member of FTE.
hey kwik does your truck have a 60 upfront or is it something bigger???
imho you may be ok with a d60 from a 350 up front. really all you got is the weight of the motor up there.
Old 10-08-2005, 10:58 PM
My truck has 5300 lb on the front axle alone. You should see how beefy the frame is on the truck. 1/4" thick steel. VERY heavy.
I don't know what front axle I have right now.
Old 10-09-2005, 06:08 AM
hey kwik,
yeah i posted the specs on junkyard dog, i got a lot e-mails back from yards who show stock.doin the job won't be a problem i own a collision shop.couple things i think i'd need to research is the computer will it cause any conflicts, steerin box and pitman arm check to see if they are differant also.
Old 10-09-2005, 11:14 AM
hey kwik,
Sounds like you are doing it right with the homework first. Let us know how it goes.
03' F550 4x4 axle widths delta charlie 1999 to 2016 Super Duty 0 07-24-2016 09:01 AM
03 Ford E550 Front Springs? Reckless7 Brakes, Steering, Suspension, Tires, & Wheels 1 06-14-2015 09:28 AM
FE crossmember install modification Dano78 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 01-19-2013 08:20 PM
supercharged 4.9L dano420 1978 - 1996 Big Bronco 8 05-06-2008 11:37 AM
05 F550 4x4 HD Steering Stabilizer Suggestions? Yellowstoned 1999 to 2016 Super Duty 1 12-13-2005 12:39 PM
Tags
4x4, 99, conversion, convert, diesel, f550, f5504x4conversion, parts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
