diesel compression ratios - Ford Truck Enthusiasts Forums
General Diesel Discussion SPONSORED BY:
Old 10-07-2005, 06:40 PM
DANDEE1996 DANDEE1996 is offline
DANDEE1996 is starting off with a positive reputation.
does anyone have a chart that has compression ritios for various brand diesel engines?
afterthought; a chart would be ideal but rare, it would be great if everyone could give the type and size of thier diesel engines as well as the compression ratios and i will make my own chart, thankyou
Old 10-07-2005, 09:48 PM
Customz's Avatar
Customz Customz is offline
Customz has a good reputation on FTE.Customz has a good reputation on FTE.Customz has a good reputation on FTE.
6.0l (03-04) = 18.5:1
Old 10-08-2005, 08:56 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i seem to remember the 88 7.3 was around 22.5 to 1
Old 10-08-2005, 12:19 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
The Powerstroke from 99-03 is 17.5:1
Old 10-09-2005, 01:38 PM
good start folks, any vehicle, any year, any diesel.
Old 10-09-2005, 02:20 PM
cookie88's Avatar
94-97 PSD is also 17.5:1
That pretty much makes this a "general diesel" thread.....
Moved to proper forum
Old 10-09-2005, 06:37 PM
thankyou, keep them comeing folks.
Old 10-11-2005, 12:30 AM
Calvin349 Calvin349 is offline
Calvin349 is starting off with a positive reputation.
pre power stroke 6.9 = 22.5 7.3 = 21
I have been reading,
Calvin
Old 10-13-2005, 05:07 PM
perky's Avatar
perky perky is offline
perky is starting off with a positive reputation.
6.0 Perkins Phasser 17.5
4.0Perkins Phasser 17.5
1004 Perkins no turbo 16.5
1006 Perkins " " 16.5
1004-4T " Turbo 16.1
1006-6T " Turbo 16.1
5.9 Cummins Turbo 17.6 innercooler
5.9 " N/a 18.5
5.9 " Indust,Turbo 16.5
GM 5.7 n/a 22.5
GM 6.2 n/a 21.5
ford 6.9L n/a 20.7
Hope this helps ran out of time will keep looking though my books latter
Dale
Old 10-16-2005, 03:26 PM
thats great, the reason i need these is cause i am doing a diesel project and need to know the compression ratios to choose what engine to use, i need the highest ratio possible. thanks!
Old 10-16-2005, 11:43 PM
444dieselrod's Avatar
444dieselrod 444dieselrod is offline
444dieselrod is gaining momentum as a positive member of FTE.444dieselrod is gaining momentum as a positive member of FTE.
What kind of project I am sure we would all gladly build it for you and let you have the credit.
an old 5.7 chev or 6.9 diesel would proly be your best bet for highest compression.
Diesel Rod
Old 10-17-2005, 07:17 PM
well,,,aaa,,, i'll tell you guys more a little later, when i figure out if it is possible.
someone told me that some old dozers (humm, i hav'nt used that z botten in a while) oh sorry was i thinking out loud again, any way someone told me that some old dozers do not have glow plugs and their compression ratios were alot higher than normal, is that true?
Old 10-17-2005, 08:30 PM
well most old tractors don't use GP's, as far I know the old 460 and 560 farmalls where the only ones that use them from IH, all the other I-6's didn't. Let me dig up an old book I have and see if it has CR for anything realy old.
Diesel Rod
Old 10-18-2005, 02:25 PM
perky's Avatar
None of the Perkins use GP,s are Cummins, the DT466 didn,t have them eather.
Dale
Old 10-18-2005, 10:46 PM
superrangerman2002's Avatar
superrangerman2002 superrangerman2002 is offline
superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.
I dunno about that, I've got a Farmall 706 diesel that has GPs, and I'm pretty sure it's a Perkins I-6. I could be wrong though.
Dam good motor too!
compression ratio iceman320 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 06-13-2013 10:27 AM
Fuel Consumption Attitude Adjustment 6.7L Power Stroke Diesel 9 12-27-2011 09:44 PM
Typical DEF Usage Chart pbruckne 6.7L Power Stroke Diesel 9 06-25-2011 10:53 PM
Piston compression ratio chart TMI 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 11 08-01-2006 10:02 PM
Dynamic compression ratio for 105 octane. rusty70f100 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 03-18-2006 10:18 PM
Tags
64, 69, 73, 73l, 92, big, cat, common, compression, diesel, engines, f350, figure, ford, ratio, ratios, stack, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
