Biodiesel MPG - Ford Truck Enthusiasts Forums
Biodiesel MPG
Old 10-07-2005, 06:19 PM
onioncasserole onioncasserole is offline
onioncasserole is starting off with a positive reputation.
Biodiesel MPG
What kind of MPG do you get with your vehicle compared to when it was petro-Diesel?
Old 10-07-2005, 09:03 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant future
I'm using premium fuel with 5% biodiesel from soybeans and it added about 1 to 2 mpg but it helped a lot with the smell and the noise from the engine. It added in this combo about .04 per gallon (2 for premium and 2 for the soy)
Old 10-08-2005, 06:11 PM
Fish370ec Fish370ec is offline
Fish370ec is starting off with a positive reputation.
Mileage
I picked up my new 06 6.0 350 a little over a week ago and just got back from a 700 mile trip. The truck already had a "few" miles on it do to being a dealer trade. In any event, I got 19mph for the trip. Averaged about 70. I have to say, that I was thrilled (understatement). Anyway, the local Meijer sells Bio, but only B20 so I need to "water" it down with petro diesel to get to a 5% ratio (according to the manual, no more then 5% should be used). In any event, if I can add even 1 mile per gallon by using Bio, then I am totally in. Better mileage and less reliance on the Middle East.
Fish.
Old 10-09-2005, 04:59 PM
Does using 100% biodiesel get worse MPG compared to using 100% petro-diesel?
Old 10-09-2005, 08:04 PM
kregars kregars is offline
kregars is starting off with a positive reputation.
From my understanding, using straight 100 (B100) will generally give you about the same results as #2 pump. However..if you are brewing your own, which is what I think your getting at, you may find that the milage clock is less often monitored but be sure to have a spare filter as B5-B100 will clean out the entire fuel delivery system and clog the filter...just depends on what ratio you go with etc.
Also from my understanding, buying straight 100 (or even B99) is somewhat cost prohibitive. YMMV (literally)
Old 10-10-2005, 02:30 AM
Sportdeck262 Sportdeck262 is offline
Sportdeck262 is starting off with a positive reputation.
Virgin B100 from a fuel supplier used to be more expensive than dino-diesel. Since the $ runnup after Katrina and Rita, the price of BD has not gone up as much. I bought B100 for $2.75/gal (including all road tax) last week from a distributor in Metro Atl. The local price for dino-diesel is $3.09-$3.49 depending on the location. Check with local fuel distributors if you want to purchase direct. It may be a pleasant suprise.
Old 10-10-2005, 12:08 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Talking
Quote:
I use B-100 in 4 rigs, Lowest gain 1.6 mpg. Best gain 3.8. Also noticed 10 percent gain in irrigation pumps of gallons per hour pumped at same rpm as dinodiesel. All engines seem to run quieter. I'll never go back to dinodiesel!!! FABMANDELUX.
Old 10-10-2005, 01:58 PM
Is there a reason why Ford only recommends B5? It seems that some/many are running B20 or even B100. Are these being run in 6.0s or 7.3s or something completely different?
Fish
Old 10-10-2005, 08:28 PM
According to International Truck--- TSI -05 -12 -21 May 2005 International will warranty engines up to B5 or 5% biodiesel if the fuel meets ASTM D975 fuel quality standards. B20 does not meet these specifications. But there is work being done within the ASTM for a B20 specification.
Old 10-11-2005, 05:22 PM
Cool, thanks - I will try the B5 and then when and if the B20 is approved for ASTM and International and Ford recognize it, then I will switch to that as it appears alot of people are having good luck with it.
Old 10-11-2005, 08:44 PM
I was using the B20 until we got the 04 and found out about the warranty issue. I have 4 diesels for the farm ( tractors etc) and 2 diesel pickups. so we go thru a lot of fuel in the spring and fall. I had no problems but the older equipment quit smoking and ran smoother than on #2.
What mpg for the 5.0 with the 700lbs. Diet? elemint 2015+ F150 14 02-25-2014 03:09 PM
Getting more MPG form a 08-V10 Dogmann Modular V10 (6.8l) 7 10-03-2013 09:37 AM
whats your MPG, or MPG improvments? xjvince Excursion - King of SUVs 65 08-18-2006 12:01 AM
engine choice for MPG bsprowl FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 12 08-28-2001 08:02 PM
Rapidly decreasing MPG Avanti 1987 - 1996 F150 & Larger F-Series Trucks 7 02-12-2001 02:57 PM
Tags
201, biodeisle, biodiesel, biodisel, f250, ford, give, mpg, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
