Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-07-2005, 05:59 PM
rangerfan's Avatar
rangerfan rangerfan is offline
rangerfan has a good reputation on FTE. rangerfan has a good reputation on FTE.
please help with excessive front end noise
We have a 04 Escape with 25,000 on it and so far its been pretty good to us. Lately we've been having excessive noise coming from the front end. It sort of sounds like we are driving with huge mudders for tires. Thanks in adance for your help. We got the tires balanced and its still loud. The vehicle is still under warranty
  #2 (permalink)
Old 10-07-2005, 06:26 PM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant future Beast12 has a brilliant future Beast12 has a brilliant future Beast12 has a brilliant future Beast12 has a brilliant future Beast12 has a brilliant future Beast12 has a brilliant future Beast12 has a brilliant future Beast12 has a brilliant future Beast12 has a brilliant future Beast12 has a brilliant future
Since it is still under warranty just take it to the dealer. It could be anything. Good luck.
-Matt
__________________
-Matt (FTE Super Moderator)
2001 F-150 S/C XLT 4x4 Sport
Check Out The Ontario Chapter
"He who is tired of WEIRD AL is tired of life" -Homer Simpson
  #3 (permalink)
Old 10-07-2005, 07:45 PM
bananaboat bananaboat is offline
bananaboat is starting off with a positive reputation.
I'd take it in but what is the noise? Tire noise? If so then I assume you have the Conti or General tires. There's nothing the dealership will do about them and your best bet is to purchase some decent tires.
  #4 (permalink)
Old 11-22-2005, 10:28 PM
atencati's Avatar
atencati atencati is offline
atencati is starting off with a positive reputation.
ours made that noise, not really a grating noise but sounds like a loud rubbing/mud tire noise. Yeah, needed a new tranny....good luck
  #5 (permalink)
Old 11-30-2005, 11:44 AM
EBTDM EBTDM is offline
EBTDM is starting off with a positive reputation.
My '02 had that type of noise that you describe. I bought good tires with alignment and balance and in the end it was the front wheel bearings.
  #6 (permalink)
Old 11-30-2005, 12:06 PM
rangerfan's Avatar
We got it fixed a couple of weeks ago. It ended up being that the front bearings were bad. It is running great now. It always made that noise since we bought it brand new. With time it just got worse and worse as time went by. With i fixed I feel like e have a new car.
  #7 (permalink)
Old 11-30-2005, 02:04 PM
yysenhimer yysenhimer is offline
yysenhimer is starting off with a positive reputation.
My wife's Escape had both front wheel bearings go bad with like 5K miles on it. Judging by the noise coming from the front end they need to be replaced again @ 75K
__________________
'05 F250PSD CC
  #8 (permalink)
Old 02-17-2006, 10:19 PM
Eakster Eakster is offline
Eakster is starting off with a positive reputation.
O-Oh
Our '03 Escape has made this type of noise since we got it, but you only hear it when cornering at speed. It makes the same noise whether its a left-hand or right-hand corner. I was worried at first, thinking it was bearings, but it definitely hasn't got any worse (had it almost a year now). The only way I can describe it is it goes 'dugga-dugga-dugga-dugga' quite fast
I had put it down to tyre noise on this vehicle, (Goodyear) now I'm worried again...
  #9 (permalink)
Old 02-18-2006, 09:51 AM
Quote:
Originally Posted by Eakster
O-Oh
It could still be tire noise. The wheel bearings, rack, factory tires and stabilizer links seem to give people problems. My 02 Escape had tire issues (Americana SUV?) and the links went bad but no bearing issues by 85k miles. The 05 Escape has 34k and hasn't developed any noise issues yet.
  #10 (permalink)
Old 04-12-2006, 07:05 AM
license2ill license2ill is offline
license2ill is starting off with a positive reputation.
The road noise compeltely changed when I changed tires on mine. The old Contis howled like no other, which may have been a part of the cupped wear they were showing on the rears, which only makes that worse. When I switched to a more aggressive all-terrrain tire, the Bridgestone Dueler Revos, it became Lexus quiet for the the frist 500 miles or so on them. They have developed an entirely different noise signature since. They make some muflfed helicopter noise around some low-speed 35mph or less corners, and a fair bit of roar between 40-50mph, but then it settles down again at highway speeds and is harldy distinguishable over other road noise and exhaust noise. I stuffed some leftover carpet remnants up into in the front footwells that have helped a little in muffling some of road noise, as well as under the load floor over and around the spare tire and under the seats and over the rear floor and passenger footwells, with a really heavy, plush carpeting we had laid in my grnadmother's house. Basically stuffed it in every nook and cranny, and luckily it matches the interior color pretty well for the parts that show. The vehicle just doesn't have very much sound insulation.
  #11 (permalink)
Old 04-12-2006, 01:47 PM
tcesni tcesni is offline
tcesni is new and has a neutral reputation at this point.
"dugga-dugga" sound like a typical pair of Continentals. The Michelin Cross-Terrain is a good replacement tire.
  #12 (permalink)
Old 12-30-2006, 09:49 PM
highlandescape highlandescape is offline
highlandescape is starting off with a positive reputation.
i get more of a whoam-whoam-whoam-whoam sound from goodyears
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
