Lowered f100 and wheels
I'd stick with 235 tall and below, they look good (my truck has 15's right now though, and wheel size isn't changing, these are brand new tires and I like normal sized wheels). You might be able to go taller but 235's tuck up pretty nice with a 3/4 drop, kind of a muscle truck look to them.
Received 1,353 Likes
on
So, a 235-50-15 and a 235-75r15 are very different tires.
that being said, I think 31" overall diameter is about as tall as you can go on a normal ride height F100. So, on a lowered rig it should be substantially shorter, unless you remove some fenders etc. I'm talking mostly about the front tires here. The rear isn't quite as restrictive.
there are some good calculators at www.4lo.com to figure out how tall a tire is given it's metric size.
as an example- a 245-50r20 is about 30" tall.
a 245-50r18 is about 27.6" tall
You will also have to adjust wheel offset to get the most tire without rubbing. I won't even begin to try and explain that :-)
kellum68
03-24-2017 12:17 PM
Mdc9966
06-10-2015 01:13 PM
BrotherMabe
67
02-25-2014 12:18 PM
