looking to purchase a '92 F-350 diesel - Ford Truck Enthusiasts Forums
Old 10-05-2005, 07:26 PM
665Paul 665Paul is offline
665Paul is starting off with a positive reputation.
Question looking to buy and convert a '92 F-350 diesel to SVO
hello, I'm interested in buying a '92 F-350 to run on either svo or wvo or even biodiesel. I'm reading alot about how to make the biodiesel and to use vo as a strait fuel. Are there problems with converting the 350 or are the conversions of injectors, glow plugs, fuel heaters and the such really requiered for the 350 to operate properly? I know that it has dual fuel tanks so doing a start/stop on petro-diesel would not be a problem.
Old 10-06-2005, 08:11 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 03-01-2006, 04:27 AM
Spincycled Spincycled is offline
Spincycled is starting off with a positive reputation.
Ive heard its best to have a heater for the fuel tanks and even a temperature gauge to keep it around 130 degrees . It will prevent the WVO from becoming thick and or hardening and clogging up your injectors, etc. Also make sure you properly filter the WVO and take steps to remove any water. Im thinking of putting my flatbed on my f150 and maybee even the engine etc later on if thats even possible. If anyone knows please help with any input..
Old 03-01-2006, 06:55 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
Welcome to FTE 665Paul and Spincycled.
Old 03-02-2006, 05:30 AM
leskwvo leskwvo is offline
leskwvo is starting off with a positive reputation.
Quote:
Yes to run straight WVO/SVO you need heat. Coolant heat is the easiest to get and use. From Heat exchangers, Hose on hose (HOH), Hose in Hose (HIH), and heated fuel pickups you can get all the heat you need in most parts of the country. If you live in Minnesota you may need to add electric heat. Your target is 160F or more for the best performance of WVO/SVO.
The pre-PSD Fords are simple to convert and hold up well. Take a look at the article over in the article section on this forum Can a Diesel run on Veggie Oil
Welcome
What problems can I expect using Bio-diesel tndiesel 1994.5 - 1997 7.3L Power Stroke Diesel 10 06-18-2008 05:44 PM
New to biodiesel. kevbits Bio-diesel, Propane & Alternative Diesel Engine Fuels 7 11-30-2007 05:13 PM
Bio diesel usage? PSNut 1999 - 2003 7.3L Power Stroke Diesel 41 08-17-2006 11:41 AM
Biodiesel power onioncasserole Bio-diesel, Propane & Alternative Diesel Engine Fuels 1 03-08-2005 10:55 AM
Biodiesel F150Canuck Bio-diesel, Propane & Alternative Diesel Engine Fuels 16 02-23-2004 08:17 AM
Tags
92, convert, f250, svo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
