Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 10-05-2005, 04:41 PM
onioncasserole onioncasserole is offline
Garage is empty, add now
onioncasserole is starting off with a positive reputation.
Good Biodiesel Project Vehicle
What would be a good vehicle to convert to use Biodiesel? From what I understand some of the older diesel vehicles don't respond well to Biodiesel due to rubber seals/parts being effected by the fuel and eventually clogging up the injectors. I've read that this really isn't a problem on vehicles from the mid 90's or newer b/c of lack of rubber parts. I would like a small diesel P/U. I noticed that Toyota made a 2.2 diesel truck in the early 80's, has anyone had an experience with these trucks? Are they good trucks? I looking for a less expensive project truck to experiment on.
  #2 (permalink)
Old 10-05-2005, 11:09 PM
bczolone's Avatar
bczolone bczolone is offline
bczolone is gaining momentum as a positive member of FTE.bczolone is gaining momentum as a positive member of FTE.
me too, but as ford the trucks id go with a 94 older ford or 95?older dodge
as for rubber parts, 99% are just the fuel lines (nothing in the IP)...not a big replacement problem just use viton lines to replace with
"they" say the best is mercedes 85older...can run it on "sand"
basically anything IDI, the newer DI have precision injectors with low tolerences that with succumb to carbon deposits much sooner (1/2 the time) as with pertoleum diesel.
as for the toyota that would be sweet, but good luck finding one...they did make quit a few D50/mitsubishi diesel pickups and i see a few here and there.
  #3 (permalink)
Old 10-06-2005, 08:04 AM
What does IDI and DI mean?
And I was going to ask about a good Mecedes as well but forgot to ask. are you referring to the Mercedes cars or trucks?
  #4 (permalink)
Old 10-06-2005, 08:16 AM
BigF350 BigF350 is online now
2000 Ford F-350
My Garage
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
adrian.erks.harris adrianerksharris
In Direct Injection. and direct injection.
Those 2.2l diesels are the most reliable engine I have ever seen. Bar none (well maybe the 2.4l engine that followed it).
They bring a new meaning to gutless though.
The Benz diesels are good, darn reliable, but with thier parts prices you would want them to be. I would still say the 2.2 Yota diesel would be the most reliable.
If you have broadband.
Check this out...
http://www.bbc.co.uk/topgear/downloa..._broadband.ram
(admittedly its the 2.4l engine. But it is essentially the same)
__________________
Adrian | 2005 4x4 Diesel Ranger CrewCab in Aus | 2000 4x4 SC/LB F350 7.3 ZF-6 in the US
  #5 (permalink)
Old 10-06-2005, 10:01 AM
bczolone's Avatar
yes i'm sure the toyota would be an excellent choice, i know i'd love to have the 4wd for hunting, but here in the U.S. i dont even know how many there are, actually only heard of them, never actually seen one.
mercedes cars...
or you could order a 4BT with a transmission, or adapt it to what ever...not sure on prices but those are much more common (4cyl. turbo diesel by cummins) found in "bread" trucks...seen several site that sell them...but ofcourse you'd have to be able to do the transplant too
  #6 (permalink)
Old 10-06-2005, 11:24 AM
Are there any other common problems associated with using Biodiesel? I.E. Like fuel congelling due to cold weather, switching rubber fuel lines over to viton. What else?
I've also heard that (regular diesel has sulpher in it to lubricate motor parts) biodiesel doesn't lubricate as well.
Also...after making a batch of Biodiesel, how does it compare pricewise with regular diesel?
  #7 (permalink)
Old 10-06-2005, 12:39 PM
paulm paulm is offline
paulm is starting off with a positive reputation.
I had a 1980 Toyota diesel pickup. That thing was one of the toughest vehicles I ever laid my hands on. It wasn't the fastest thing on earth but it got around 40 mpg. I'd love to find one again for beating around town. I'd still have it except I got it stuck one cold December morning and it was low on oil, I revved it too high and it spun some bearings. By that time (around '86) the body was all beat up so we just parked in the pasture. Some passerby ended up buying it for a $500.
__________________
Paul
2007 F250 4x4 C/C XLT White 6.0/Torqshift
  #8 (permalink)
Old 10-06-2005, 08:17 PM
bczolone's Avatar
i haven't read anything as to problems with lubrication...Univ. of Missouri and Idaho and a few other have abstracts on line you can read and i know some still have ongoing projects so i would start searching for those...i tend to think they have more viable information than word of mouth...including mine. i make mine for about .93 a gallon, but i get my waste oil for .33/gal pre filtered so it save a bunch on the mess and the filtering, but theoretically it would be .60/gal if i gathered it my self. Methanol was 2.50/gal for the last tank and i forgot on the NaOH, but i buy it by the case; Red Devil 100% Lye....its the equipment thats costly on start up.
  #9 (permalink)
Old 10-06-2005, 09:29 PM
I didn't know you could but WVO pre filtered. How did you come about finding your source?
  #10 (permalink)
Old 10-06-2005, 10:45 PM
bczolone's Avatar
guy walked into my friends shop last year and again this year...i think he says he collects something like 10000gal a week?
Tags
24l, biodiesel, ford, good, mercedes, project, truck, trucks, vehicle, vehicles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
