Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 10-04-2005, 08:46 PM
JetBlackBronco's Avatar
JetBlackBronco is starting off with a positive reputation.
Question rear disc brake conversion????
does anyone know if there is conversion kit available for a 91 bronco, to convert the wimpy rear drums over to disc brakes. i know the fords came with discs in 92 or 93, but it was a 4 wheel anti locks. i want to keep my from locking brakes, and i want my backs to work better and work properly in the rain/mud/under water.
__________________
1993 F150 Lightning, color: Bright "Ticket Me" Red.....completly stock...FOR NOW.....MuHAHAHAHAHAA
1991 "Jet Black" Bronco Custom, 302 V8, E4OD, 32x11.50 BFG AT's, dual output Flowmaster American thunder system
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 10-04-2005, 09:12 PM
Barrin is starting off with a positive reputation.
thats a good Idea...
Im with you Brother.....
  #3 (permalink)
Old 10-04-2005, 09:26 PM
cjbronco is starting off with a positive reputation.
Oh man, theres been some debates about this one. I personaly dont think there's a need for rear disc's, just a hydroboost system. However, to each his own. Look at ford racing homepage and ive seen a rear disc brake conv. kit for you 8.8 for about $350 or so. Good luck.
  #4 (permalink)
Old 10-04-2005, 10:31 PM
greystreak92's Avatar
greystreak92 is gaining momentum as a positive member of FTE.
There is absolutely no comparison for the stopping power that disc brakes provide over drums. Its a fact that vehicles with front disc/rear drum brakes rely on the discs to provide better than 60% of the overall braking power for the entire braking system. Rear disc conversions increase rear axle sytopping power and if nothing else reduce the frequency with which the front pads must be replaced. With this in mind Check this page at The Streetrod Manufacturing Company
__________________
Only stupid question is the one you don't ask.
1993 Bronco XLT 5.0, E4OD (at the moment)
1992 F-150 XLT 4.9, M5 (at the moment)
2007 Dodge Caliber SXT 2.4 VVT, shiftless auto (grocery getter)
2007 Saturn Sky Redline 2.0 VVT turbo, 5-speed (The Toy)
Big Bronco FAQ's
  #5 (permalink)
Old 10-04-2005, 11:25 PM
those look great, but will they work with anti lock brakes?
and another question....how hard is it to remove the axles to install this kit?
__________________
  #6 (permalink)
Old 10-04-2005, 11:33 PM
93BigBlackBronco is starting off with a positive reputation.
[quote=JetBlackBronco]those look great, but will they work with anti lock brakes?
Does a disc brake conversion require an adjustable proportioning valve?, and if so will the ABS work correctly.
Keeping in mind that ABS sensor on the rear is on the differential carrier not the individual wheels like the front.
I have a disc brake conversion I will be installing when I regear. Just want a few answers to avoid headaches
__________________
1993 Bronco XLT 5.8 E4OD
THE BETTER THE 4 WHEEL DRIVE THE FARTHER OUT YOU GET STUCK.
  #7 (permalink)
Old 10-05-2005, 03:41 PM
Guys, guys, disc brake conversions work EVEN BETTER with ABS because you DON'T need an adjustable proportioning valve, the ABS computer reads the brake response and adjusts fluid flow to the rear brakes accordingly. Remember that the sensor for the rear portion of the ABS is the VSS in the top of the rear diff. housing. So, swapping to rear dics with ABS actually makes the swap a simpler project than if you had a standard barking system.
__________________
Big Bronco FAQ's
  #8 (permalink)
Old 10-05-2005, 05:37 PM
body9599 is starting off with a positive reputation.
Quote:
does this apply to those of us without VSS? 89's didn't have VSS right?
__________________
1989 XLT 302 (5.0L) V8
KandN, Crane Cam, MSD 6A and Coil
Mark VIII Fan, Ford Racing Wires
200 Amp 3G Swap, Transgo HP AOD
JVC HU, Pioneer Spkrs, 10" Sub
  #9 (permalink)
Old 10-05-2005, 08:27 PM
aurgathor is gaining momentum as a positive member of FTE.
Unless loaded, the Bronco is a front heavy vehicle, with around 60:40 or so split in weight/axle, so it should not come as a surprise that most of the braking is done by the front brakes. Add the weight transfer during braking, and the ratio is even higher, so regardless of what you have in the rear, the front brakes will do most of the braking, no matter what. IMHO, the only time rear disc would be clearly beneficial is when fully loaded, or towing a sizeable trailer.
Having said that, does anyone have any hard data to show how much better is braking with rear disc brakes?
  #10 (permalink)
Old 10-05-2005, 08:29 PM
That makes sense Thanks Grey
__________________
  #11 (permalink)
Old 10-05-2005, 08:49 PM
so how hard is it to remove the axles? i have never done this, and id like to know what im getting myself into if i decide to do this.
__________________
  #12 (permalink)
Old 10-05-2005, 09:11 PM
94 XLT White/ Silver 302's Avatar
94 XLT White/ Silver 302 is starting off with a positive reputation.
To remove the axles,
remove rearend cover
remove the pinion shaft lock-bolt
pull pinion shaft out
push axles in
remove c-lock from the groove in the end of the axles
pull axles out.
If you have a Haynes book it should have pictures of the axle removal.
__________________
94 XLT White/ Silver, 302, E40d, K&N filter charger, under drive pulley
Hedman headers, BBS throttle body, Bassani Y pipe with 3" high flow converter, 2-1/2" duals, warn hubs, American AR-23 wheels 15x10, Nitto Terra Grapplers 33's, 4:10 gears, 2 1/2" Rought Country lift, Rancho 5000 shocks 6ea.
  #13 (permalink)
Old 10-05-2005, 09:44 PM
Quote:
Those trucks without the VSS/ABS on the rear axle will most likely need an adjustable proportioning valve.
In response to argathor's comments about front heaviness and weight transfer I don't refute any of it. But, in those instances when we who do load our trucks with gear and do use them to tow, wouldn't be be nice to know the added beneift of discs on the rear are there WHEN they are needed? You may not need the jack and the tire iron all the time either but you sure are glad they are there when a tire goes flat. I see rear discs as an improvement not unlike adding a selectable locker. No, it may not come in to play every day but when it does, its damned nice to have it. I don't know about the rest of this community, but I for one find myself using my Bronco to its full potential on a regular basis.
__________________
Big Bronco FAQ's
  #14 (permalink)
Old 10-05-2005, 10:38 PM
gov2mod is starting off with a positive reputation.
JetBlackBronco, while I would like to have disc brakes on my Bronco's as well I wasn't aware of any that had factory rear disc. I've got a 90, 91, and 93 Bronco and they all have drum on the back.
  #15 (permalink)
Old 10-05-2005, 11:26 PM
i dont remember what year it was, but they did come with rear discs, along with the f150s
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
