Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #46 (permalink)
Old 05-12-2008, 11:31 PM
shia1 is starting off with a positive reputation.
Quote:
Originally Posted by bossind View Post
You need to gut that, it has a spring and bearing in it - remove them.
What I'll get after removing the spring and bearing - more pressure on rear break lines?
  #47 (permalink)
Old 05-13-2008, 07:30 AM
bossind's Avatar
bossind is starting off with a positive reputation.
Quote:
NO, its a valve designed to keep a small a mount of pressure on the rear cylinders of a drum brake system - so they don't have to move so much when you hit the brakes. If you leave the valve in when converting to rear disc brakes you will over heat and wear the pads out very quickly.
__________________
-Steve
96 Bronco, SAS, 4.88, 35s, Hydro Boost, 3" exhaust, 4 wheel Disc brakes, Sag PS Pump.
  #48 (permalink)
Old 05-13-2008, 10:39 AM
Ok. Thank you for your answers. And the last questions - how much mm. you've taken off from the axle shaft to take on it the break disk? Did you do anything with the parking brake cable? What is the length of new wheel bolts or I can use it from the old drum brakes (I think that wheel bolts must be longer then old drum wheel bolts).
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
