Quote:
Originally Posted by shia1
What I'll get after removing the spring and bearing - more pressure on rear break lines?
NO, its a valve designed to keep a small a mount of pressure on the rear cylinders of a drum brake system - so they don't have to move so much when you hit the brakes. If you leave the valve in when converting to rear disc brakes you will over heat and wear the pads out very quickly.
__________________
-Steve
96 Bronco, SAS, 4.88, 35s, Hydro Boost, 3" exhaust, 4 wheel Disc brakes, Sag PS Pump.
