Power Steering Pump.
Hi,
I have a 98 F-150 4.2L with 250,000kms.
When the truck is at idle the power steering does not work. If I hit the gas and rev it up a little the power steering starts to work. Fluid level is fine.
Is it time for a new pump?
How hard is it to change? Can it be done in an evening?
Any special tools required?
I need to get this fixed as my girlfriend drives it and she does not have enough muscle to manouver it in parking lots.
I called my local parts depot and the pump is about $160 CAD after the core change.
Thanks in advance.
Thanks in advance.
All I have ever done, (when I replace the lines), was to have the cap off, then have someone else slowly turn the wheel back and forth starting in small movements first then increasing the movement as the air is worked out, until you are getting no more bubbles and the fill level is good.
