reset computer - Ford Truck Enthusiasts Forums
reset computer
Old 10-04-2005, 06:07 PM
11rich11 11rich11 is offline
11rich11 is starting off with a positive reputation.
Unhappy reset computer
hi
my 7.3"s been givin me some grief. stalled out then didn't want to start,couple of mins later fired rite up, ran like a top for a week . went to get beer come out didn't want to start,couple of mins later fired rite up. any way to reset computer or do ya think I should take her to the shop ?
thx
R
Old 10-04-2005, 06:21 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
PowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to behold
unhooking both batteries for a more than a half hour will reset everything, and it will erase codes. it MAY be a CPS problem.
Old 10-04-2005, 09:30 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
I would take that one step further and say it's probably a camshaft position sensor problem. Given the available information.
Old 10-04-2005, 10:49 PM
thx guys,is a cps sensor a big deal & would it have anything tadoo with an aftermarket kicker chippy thing ???
Old 10-05-2005, 08:51 AM
mueckster's Avatar
mueckster mueckster is offline
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
If you have a computer installed "piggy back" chip, problems could be caused by loose contact between the chip and circuit board. Try cleaning these contact points.
Old 10-05-2005, 09:23 AM
RAMPAGE_F350's Avatar
RAMPAGE_F350 RAMPAGE_F350 is offline
RAMPAGE_F350 has a very good reputation on FTE.RAMPAGE_F350 has a very good reputation on FTE.RAMPAGE_F350 has a very good reputation on FTE.
Hey Strokin, when you unhook the batteries are you unhooking the neg side of em or posi?
Old 10-05-2005, 10:19 AM
marvinlong's Avatar
marvinlong marvinlong is offline
marvinlong is starting off with a positive reputation.
sounds like cps. takes a 10mm socket and small ext. there are some posts with pics on the site. i got mine from navistar (international) less than a hundred bucks. ask the stealer what they get for one. well thats too much!!!!
Old 10-05-2005, 11:55 AM
Fordafied's Avatar
Fordafied Fordafied is offline
Fordafied is starting off with a positive reputation.
Quote:
Unhook either side and it only takes 5 to 10 minutes. Turn on your headlights to drain any residual power. That is all it takes.
Old 10-05-2005, 01:07 PM
thx everybody , if I take her to the shop & hook it up to a diagnostic will it tell me that it's the cps sensor or will they try & give me the run around
Old 10-05-2005, 01:58 PM
Fordafied's Avatar
Probably. Autozone around here will scan it for free and tell you what is wrong. May want to try that route 1st.
Old 05-02-2008, 05:59 PM
devriesj39 devriesj39 is offline
devriesj39 is starting off with a positive reputation.
i just hooked up a superchips tuner to my 99 superduty and it comes up as "not original diagnostic settings" or something like that. if i reset the computer by unhooking the batteries, do you think that would do the trick. thanx
Old 05-02-2008, 06:08 PM
cookie88's Avatar
Wow...old thread. Were you installing the tuners performance program, or using it for it's diagnostics when you got that message?
Old 05-02-2008, 06:26 PM
Markadeck's Avatar
Markadeck Markadeck is offline
Gone, but not forgotten
Markadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant future
This time I decided to look at the original posting date before answering. When my Superchip quit years ago I of course replaced the CPS. Still no start, so I just had it towed to the stealership. The stealership told me the chip had everything out of whack and pulled it. It worked and it took me a few days to get a new chip from Superchips, but it's been fine ever since. But now I have my brandnew DP 6 tunes, and it's a lot more fun than just a single setting 80 hp chip, although without the Superchip my truck was no fun at all to drive.
Old 05-02-2008, 10:00 PM
i was trying to performance tune. the diagnostics worked fine. are those made to work on only one truck after the first time or is there some way to reset them
Old 05-02-2008, 10:41 PM
GEugeneS GEugeneS is offline
GEugeneS is starting off with a positive reputation.
Quote:
Wasn't there a Ford recall on the CPS and won't they replace it for free?
Adding shims to 10.25 open rear resto-mod 1987 - 1996 F150 & Larger F-Series Trucks 1 02-04-2015 02:57 PM
Computer reset / emissions test lpwana Ranger & B-Series 6 10-31-2010 08:52 PM
E4OD trans filter fell out crazyF250 1987 - 1996 F150 & Larger F-Series Trucks 9 07-04-2008 08:42 PM
97 F150, Intermittent won't start dirtslammer 1997 - 2003 F150 2 05-17-2005 02:59 AM
computer reset after air filter upgrade wizard 6.0L Power Stroke Diesel 0 10-17-2003 04:55 AM
Tags
1999, 2009, 4x4, 60, 73, computer, diesel, ecu, f250, f350, ford, nvk3or, powerstroke, reset, resetting, superchips
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
