Nova Scotia Join Chapter, Leader:
Hello!!
Old 02-28-2006, 07:14 PM
bossind's Avatar
bossind
bossind is offline
Hello!!
Whats up folks? Any plans, projects on the go?
Old 03-01-2006, 05:05 PM
MatthewC's Avatar
MatthewC
MatthewC is offline
Take the Bronco to Rocky Road and have them do up my welding so I can get the bugger steet-able. Wanna seafoam it there too.
Old 03-01-2006, 10:33 PM
bossind's Avatar
bossind
bossind is offline
Oh well we could have done that at the school! Should have gave me a call! I'm doing my quater panels over the march break and a hydroboost brake system.
Old 03-02-2006, 03:11 PM
Motoshrump's Avatar
Motoshrump
Motoshrump is offline
Just finished the exhaust on my 93 F150 2wd 302. Long Tube hedman headers, 2.5" front pipe flowing into a 3" single in single out flowmaster 40 series delta flow. Dumped it out in front of the right rear...........WOW! Sounds great! With the short tail pipe it resembles a mustang H.O. Works even better than it sounds too! Next is going to be the B&M mechanical shift kit (E4OD) and a set of 3:55 gears to replace the old 3:08's. I run 31" off road tires so the jump in gearing is enough to cancel out the effect of the larger tires. Thats all for now.....
Old 03-04-2006, 11:07 AM
bossind's Avatar
bossind
bossind is offline
Sounds good! I have a rear diff 8.8 from my 96 bronco with 3.55s in it, could give you a deal on it. I went with 4.10s in my bronco and to make it easy I picked up a 8.8 from the junkyard and rebuilt it with 4.10s and swapped the diff into my bronco when it was done. I also have a set of 3.55s from that diff. Let me know.
Old 03-06-2006, 04:51 PM
MatthewC's Avatar
MatthewC
MatthewC is offline
I may take you up on some help. Mid-late March when the boys are done the welding, I need to install the core support I bought from LMC. Im thinking that I am gonna install a new timing chain while the front end is torn apart.
-Matt
Old 03-06-2006, 07:45 PM
bossind's Avatar
bossind
bossind is offline
Sure bud, just let me know. I have mine in the school right now, I just got back from installing a hydroboost braking system- bit of a job cause I didn't buy a kit so i have to sourse everything. But its getting there, should stop by sometime.
Old 03-09-2006, 06:36 PM
MatthewC's Avatar
MatthewC
MatthewC is offline
You would'nt happen to know where I can get my hands on a body mount frame hanger would you? The hole on one of mine is rotted out and the mount is dropping through.
-Matt
Old 03-09-2006, 09:59 PM
bossind's Avatar
bossind
bossind is offline
Junk yard, or make a new one.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Hello!!
