dash gauge pod for 97 F350
Old 10-03-2005, 12:52 PM
MattB_1442's Avatar
MattB_1442
MattB_1442 is offline
I'm having trouble locating a 3 gauge pod that goes on the dash above the radio. I've seen them before. Does anybody know where I can find one? Mine's an OBS truck.
I don't want one above the rear view mirror - too hard to watch and drive at the same time. BTW, the pillar pod will gave EGT, engine temp and boost. I want to have oil pressure, ammeter and maybe a clock on in the dash pod. I had originally thought about a tranny temp gauge, but mine's a manual so it would not be "necessary".... I still ahven't decided on that one yet.
Old 10-03-2005, 01:04 PM
touchofgrey's Avatar
touchofgrey
touchofgrey is offline
Here ya go: http://www.xtremediesel.com/index.as...sh+pods&Page=1
Old 10-03-2005, 06:03 PM
stroker2's Avatar
stroker2
stroker2 is offline
MattB, there is not alot of selection for OBS, pre-'99, gauge pods. The link touchofgrey gave you was for '99 trucks. I've seen pictures of installer "modified" gauge pods above the radio and also to the left of the steering wheel on OBS truck. I believe the dash pod to the left of the steering wheel was a modified Dodge pod on an OBS Ford truck. (sacrilege, LOL) At one time I considered modifing a Dodge center dash mount, but thought the streering wheel would block the view of the gauges. The largest selection of pods I've seen were at ProPod.com and egauges.com. ProPod does not direct sell, but I believe xtremediesel.com, dieselmanor.com and bayareaperformance sell ProPod. It might take a phone call to get them to order what you want. Egauges carries VDO pods. Make sure you get them "angled" the way you want them, since there are pods for left and right of the steering wheel. In my quest, I did not find any dash mounted pods that were made specifically for OBS Ford trucks. Good luck shopping.
Old 10-03-2005, 09:42 PM
cookie88's Avatar
cookie88
cookie88 is offline
Thread moved to proper forum.
Old 10-04-2005, 02:18 PM
MattB_1442's Avatar
MattB_1442
OK, I just noticed the forums were split .... that's what happens when you don't visit for awhile.
Thanks, Stroker2. I'll check out your lead. It's kind of a bummer that they build these trucks to last, then you have trouble getting certain aftermarket stuff for the older ones....
Old 10-04-2005, 08:19 PM
cookie88's Avatar
cookie88
cookie88 is offline
Check some of the site's sponsors. I know Geno's Garage carries a few gauge mounts for the OBS trucks back to 92.
Old 10-05-2005, 10:31 AM
MattB_1442's Avatar
MattB_1442
Thanks, Cookie. I've decided on using the Isspro Bullet mounts from Geno's for oil pressure and ammeter on the dash over the radio in addition to a 3 gauge pillar pod with EGT, boost & engine temp. I'm going to get Isspro for all the gauges. It oughtta look pretty cool.
Old 10-05-2005, 06:44 PM
cookie88's Avatar
cookie88
cookie88 is offline
That will look very cool. Where are you going to pick up the engine oil temp, or did you mean coolant for engine temp?
Old 10-06-2005, 08:43 AM
MattB_1442's Avatar
MattB_1442
Yes, I meant coolant temp.
It WOULD be easy to go for the "cockpit" look, if not for the emptywalletitis that would result - trans temp, diff temp, oil temp, fuel pressure, then I'd have to add on-board air so I could have an air pressure gauge. AND I'd have to replace the tach, speedo and fuel gauges too! LOL
Old 10-06-2005, 10:18 AM
wycowboy's Avatar
wycowboy
wycowboy is offline
I used universal gauge cups. found thamon line they look good and you can mount them any where each gauge is mounted singaly which I find helpsingettingright where you want it. I'l looks for the site name.. J
Old 10-06-2005, 06:27 PM
MattB_1442's Avatar
MattB_1442
Exhaust & Gauges ordered ..... WOOHOO!! can't wait! All in the name of better milage, of course ;-)
Old 10-06-2005, 08:01 PM
cookie88's Avatar
cookie88
cookie88 is offline
That's what credit card are for...buy a lot now, pay a little forever . At least that's what I've heard, I just suffer along with emptywalletitis as well.
finallyo3gt
18
07-16-2016 08:47 PM
SoCalAngler
32
01-01-2016 12:25 PM
Wvstream71
Computer Chips & Tuners
08-30-2015 02:21 PM
akamacgyver
10-09-2012 01:20 AM
'94IDITurbo7.3
11-16-2011 08:37 AM
Quick Reply: dash gauge pod for 97 F350
