Transmission Oil Help Quick!
well, i am going to replace my transmission oil, and i think i have decided on Mobil 1 Synthetic ATF. i went searching on ebay, and i saw 20 quarts (what i need) of Mobil ATF 3309. here is what the auction stated:
Mobil ATF 3309 is recommended for use in transmissions made by Aisin AW requiring a fluid approved against Type T-IV, JWS 3309, GM 9986195, Saab 3309, Volvo 1161540, and Audi G-055-025-AZ. These Aisin AW transmissions are used in CERTAIN domestic and foreign vehicles, including Toyota, Lexus, Audi, Saturn, Ford, Volvo, Volkswagen, Saab, Porsche, and Mitsubishi.
This is not a Dexron, Mercon ATF and is for newer cars, typically five speed automatics. Only dealers carry this ATF (own labels) and costs $11-16 per quart.
Check your owners manual or dealer to see if you need any of the above specs for your ATF. If you do, you cannot use other ATF's including synthetic or "universal" ones without risking a transmission damage.
it said that it is "not a Dexron, Mercon ATF''... but i need a MerconIII fluid, right? is this the stuff to use? its only $3.85 a quart on the auction block.\
i was looking into AMSOIL ATF. it seemed good, but i read that you should not use oil rated for both Mercon and Mercon V. but this oil says:
AMSOIL ATF is recommended for automotive and hydraulic applications requiring any of the following specifications:
- GM DEXRON® II, DEXRON III
- Ford MERCON®, MERCON® V
- Chrysler ATF+ through ATF+4®
- Honda Z-1 (Not for use in CVT transmissions)
- Toyota Type T and T-IV
- Mitsubishi/Hyundai Diamond SP II & III
- Allison C-3, C-4
- Caterpillar TO-2
- Voith G1363
- ZF TE-ML 14C
- Mercedes Benz 236.1, 236.6, 236.7, 236.9
- BMW 7045E
- SAAB 3309
