Antislosh module?? - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Antislosh module??
Old 09-30-2005, 12:14 AM
killerb1 killerb1 is offline
killerb1 is starting off with a positive reputation.
Antislosh module??
My 92 Aerostar needs an antislosh module. Are they still available? Where?
By the way, it helps to use a meter that works when measuring resistance in the sending unit ! I decided to check it one more time with a different meter before I ordered another one. Guess what?! The new one worked fine.
I definitely traced it to the antislosh module this time. Oh well! Win some, lose some!
Old 09-30-2005, 01:45 AM
96_4wdr's Avatar
96_4wdr 96_4wdr is offline
96_4wdr is gaining momentum as a positive member of FTE.
see this thread on subject
http://www.ford-trucks.com/forums/sh...81#post2870381
dealer only item
Old 09-30-2005, 05:27 PM
JTHill24 JTHill24 is offline
JTHill24 is starting off with a positive reputation.
Killerb1:
Check the Slosh Mod for solder cracks. Most of the time if you re-solder the mod it will
start working again.
Jay
Old 09-30-2005, 08:19 PM
cookkd cookkd is offline
cookkd is starting off with a positive reputation.
Check eBay for a standard dash module and get it from that....paid less than 20 bucks for mine....solved the problem......
Old 10-01-2005, 01:11 AM
krankshaft's Avatar
krankshaft krankshaft is offline
krankshaft is starting off with a positive reputation.
First as suggested check for solder breaks and repair them as necessary if you can't find any.
Check for faulty components check the diodes with your multimeters diode checker make sure you touch the negative probe to the end of the diode with the black band and the positive to the other end.
Also check the resistors for correct resistance with your multimeter. What is a resistors proper resistance you ask look at the color bands and they tell it to you. Here is a site that does the converting of the color bands to OHMS for you.
http://www.ealnet.com/m-eal/resistor/resistor.htm
As for ICs the only one you'll come across in an OP Amp which is a common IC you can purchase at Radioshack for about $1.49 if its an OP Amp there will be the letters LM printed on the IC followed by numbers for example LM-524N in this example don't worry about the N LM-524 would suffice. I have blown out a couple of these myself on electronics projects just a little current in the wrong direction or on the wrong pin renders them useless. However its all or nothing either the IC doesn't function or it does.
But what I think is wrong with your slosh module is a capacitor isn't storing current which allows the needle on the gauge to remain in the same place (the current to remain constant on the fuel gauge) even if the potentiometer in the gas tanks resistance is going up and down. You are likely to see one of two types of capacitors either axial or upright axial just means its a capacitor on its side.
You can pick up your replacment parts at Jameco.com at a substantial savings.
If your adventurous while this would be no problem for me if your new to electronics it may seem a little confusing .
Anti-Slosh Module Pinout? WhiteWidow Ranger & B-Series 0 12-31-2012 05:47 PM
Anti-slosh....a.k.a. crazy gas gauge DOUG5G Aerostar 2 10-03-2010 10:46 PM
anti-slosh module Hussler 1994.5 - 1997 7.3L Power Stroke Diesel 10 04-22-2008 02:38 PM
anti-slosh module bertha66 Aerostar 5 08-09-2005 03:28 PM
Amp/Antislosh Module location 1994 Explorer poknox Explorer, Sport Trac, Mountaineer & Aviator 1 08-04-2005 03:59 PM
Tags
aerostar, anti, antislosh, check, dummies, ford, lm524, module, opamp, parts, price, repair, repairing, slosh, truck, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
