FM Radio died
yes, it's about the size of a cable TV cable....slightly smaller maybe. will be seperate from the main radio harness. in fact it's usually totally seperate, not hooked to anything else at all. hope this helps.
there's a picture of it here. it's the wire with the string on it in the second pic.
Heres the procedure the special tool used to remove the radio can be substituted by two bent coat hangers.
Removal
1. Disconnect the battery ground cable (14301).
2. Remove instrument panel (04320).
3. Insert Radio Removing Tool T87P-19061-A into tool insertion holes on the edge of the radio face plate. Press in 25.4mm (1 inch) to release radio retaining clips. Pull radio chassis (18806) from instrument panel using tool as handles.
4. Disconnect the radio antenna lead in cable (18812) and wiring connectors (14487).
Installation
If radio chassis is being replaced, transfer support to new radio chassis.
1. Connect the radio antenna lead in cable andwiring connectors.
2. Position the radio chassis in the instrument panel and slide the radio chassis on the instrument cluster control mounting plate until holding brackets engage.
3. Install finish panel.
4. Connect the battery ground cable.
5. Check the operation of the radio chassis and engine (6007).
6. Reset clock.
Removal
Installation
6. Reset clock.
OK, have got this far and have my wire hanger as the substitute tool, but cannot figure which holes to insert into. There are four holes, 2 top - 2 bottom, on the face plate, and what look like two pop rivets underneath the radio. Have tried all with no success.
"Insert Radio Removing Tool T87P-19061-A into tool insertion holes on the edge of the radio face plate. Press in 25.4mm (1 inch) to release radio retaining clips. Pull radio chassis (18806) from instrument panel using tool as handles."
http://www.carstereohelp.com/stereoremovalFordProbe.htm
basic idea shown, Aero is very similar and exact same technique, can do one side at time with coat hanger or make two.
google search > Ford radio removal
more than you ever want to know about the subject
