Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 09-29-2005, 06:29 AM
JZue1 JZue1 is offline
Garage is empty, add now
JZue1 is starting off with a positive reputation.
IDI or DI
Hello all, Been thinking alot about getting into the BD craze....With the price of gas seems like the smartast thing. My problem is I own a 2004 PSD. So, I've been hearing that IDI is the best system to have. Now, my question is....What is IDI and DI? Also What year did they shift over to DI and how can I tell? I love my 6.0, but I really want to get into the BD. Any info will be greatly appreciated. Best site on the internet...Thanks
  #2 (permalink)
Old 09-29-2005, 09:13 AM
DeepRoots DeepRoots is offline
DeepRoots is gaining momentum as a positive member of FTE.
biodiesel is not so much a problem with DI engines. WVO is often a problem however.
__________________
-76 F100 390FE
-63.5 Galaxie 500 -429cj
  #3 (permalink)
Old 09-29-2005, 11:48 AM
Thanks for the reply, so I really shouldnt have to worry too much if I slowly start sweeting my fuel with BD. Like starting out at 10% than slowly working my way up.
  #4 (permalink)
Old 09-29-2005, 01:51 PM
bczolone's Avatar
bczolone bczolone is offline
bczolone is gaining momentum as a positive member of FTE.bczolone is gaining momentum as a positive member of FTE.
biodiesel has shown consistantly to be a problem in High Pressure Direct Injection; source include the U. of Missouri and Idaho tests...the problem is incresed carbon deposits on injector tips at double the rate of DF2...its the IDI (94-) that fall into the "no noticable" difference in wear catagory. Remeber that the carbon is greater, the power and milage less, although I don't think thats a reason not to start. If you do decide to run B100 just be aware of potential injector wear, at the least. If everything was perfect and a injector would normally last 100k then figure on 50k with the BD...I think safely I wouldn't use more than B20 in my 2004 6.0, but am trying to find another 94- ford instead. I make mine for about .93 a gal. with .33 going to buying prefiltered waste oil so I don't have to go collect or pre-filter it. IDI is OK because of the "pre-chamber heating" (?) prior to entering the cylinder along with the lower pressures and lower tolerances...look up the University of Missouri's reports the talk specifiaclly about those problem and using two 93? Dodge Pickups for long term testing.
  #5 (permalink)
Old 09-29-2005, 07:14 PM
ohh and for your information....
ford reccomends no more than 5% of the fuel to be bio.
international however says 20% is just fine.
on another note, I would make sure the fuel is made perfectly.... More exacting injection in these new fangled diesels. Plus alot more to fix a screwup.
My 89 could run on a greasy rag.
__________________
-76 F100 390FE
  #6 (permalink)
Old 09-29-2005, 09:45 PM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant future
f250juggernaut
IDI= Indirect injection. 1994 and earlier Ford diesels
DI= Direct injection. 1994.5-current Ford diesels.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
Tags
carbon, deposits, idi
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
