Radius Arm Nut
Radius Arm Nut
I'm getting ready to replace my radius arm bushings. I have a 78 e-150 (2wd, twin I beam).
I got a new set of polyurethane bushings.
My plan was to remove the radius arm brackets (they are bolted to the frame). But I don't have a socket big enough for the nut on the end of the radius arm.
What size is this nut? It's bigger than 1".
Is there any reason not to replace these bushings by removing the bracket from the frame?
Thanks.
Thanks.
thats the way i change mine,in fact i couldnt get them apart without taking the bracket off.... there shouldnt be any pressure on it, cause i didnt even have to jack the truck up to do it, but you better until you know whats going on with it....as for the nut size, i used a large crecent wrench on it....
Stabilizer bushings
You already have one thing in your favor. Some trucks had brackets riveted to the frame. I loosened the big nuts with a 14" pipe wrench with 3' of pipe on the handle. It still took some real effort. I would have never gotten them off if I had dropped the brackets first. The bracket bolts were just about as bad. They weren't rusted but Ford put undersized nuts on them and they had to be unthreaded with a half inch ratchet and a breaker bar, all the way to the end of the bolts. There was no finger turning. I guess that they had to be tight if they were taking the place of rivets. I used PB Blaster but it really didn't penetrate. I sprayed mine and put them back on. It would take an earth quake to loosen them.
Yours may not be as bad, but be prepared. My '79-F-250 is Arizona clean, underneath. Parts man told me that urethane bushings sometimes squeak but mine don't.
