The rotors...they just won't come off.
97 F-150 4x4
I've been working on this all afternoon. I've had no luck getting the rotors to budge. I soaked them with plenty of PB Blaster and I've been beating on them with a 3lb sledge with no avail. I also tried heating them with a Burnz-o-matic but that didn't really do much (15 minutes and they were only warm). Any suggestions would be great. Thanks.
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Moved and member notified
Unfortunately, a big 'ol hammer may be your last resort. If want to try to keep the rotors, you could try using a piece of 2x4 for the hammer to hit and protect the rotor. This is kind of common on this truck. As a matter of fact, I was talking to a mechanic friend of mine and told him I'm gonna have to do my brakes and I'll be buying rotors. He said he had to beat them off of the last couple of trucks/expeditions he did. If you decide to replace the rotors, slap some anti-seize on the back where they contact the hub and it will help protect them from freezing to the hub. Good luck.
dont beat on them you will just ruin your bearings...use a die grinder and go in 1/2" from the edge of the huband cut appox. 3/16" deep 3/4" of the way around the rotor and then take a chisel put in in the middle of where you cut..just one hit with a hammer will "pop" them loose ...i have found this is the best way as not to heat up the bearings or beat them to death....
good luck
good luck
Originally Posted by PrimaryZMan
thanks for the tip, I searched last night but didn't come across the thread I just found (the bolt trick)..lots of good tips in there, it should be stickied.
Real easy.
Now, if you plan on turning them, this is obviously not the way to go.
Originally Posted by GammaDriver
um... is the bolt trick where one unloosens the nuts, then drives it? If not, I'm missing something.
Thanks!
Thanks!
