Truck will start but has no power
I need some help. I have 2001 F250 4X4 PSD 7.3L. The engine will start and idle normally, I can drive about a mile and it begins to running very roughly and produces alot of blue smoke. If I shut it off want a minute or two it will crank back up but runs very roughly, loud pinging and the truck will do about 15mph with the pedel to the floor. If I wait 20 or 30 mins. it will run normally for about a mile again.
I have replaced the inline fuel pump and the fuel filter. Do you have any suggestions?
Originally Posted by dougplace
would it be one of the individual injector o-ring? is so how would I find out which one it is?
Well, mine is doing the same thing. After a while it will start and the problem goes away. It is some how related to the engine temperature. The engine starts fine, a minute or two later, runs rough and eventually dies. Hard to start, lots of smoke, starts and dies and finially starts and blows out and then is fine until the next time it is cold, as in coas cold as it gets in the summer. It is something electronic, it sort of clicks on and then clicks off and is gone. I do have codes P0683 - Glow plug/heater module comm problem (this code came up long before this problem and didn't cause the issue and P1212 - Inj. control press lower than expected (engine cranking).
Has anyone fixed this problem?
Injector Pressure Regulator
High Pressure Oil Pump.
Originally Posted by ceopi
I changed the ICP on mine and no change ....
Beyond that, I can't help you as I've never done the job myself. Good luck.
You know there is at least 5 guys claiming this same problem. I think it must be electrical, because mine starts and stops like flipping a switch. The engine is loading up, like a stuck float on a carberator. Once it stops, it takes a few seconds to clean up and it produces a ton of smoke. Something is flooding the engine. Any thoughts?
Found the problem with f250 7.3l with no power
There is a filter in the fuel tank. My was completely plugged up with trash.
The my dealer worked on the truck for two weeks and still could not solve the problem. Out of pure curiosity I removed the fuel tank. Inside I found a filter(which the dealer said was not there)I cleaned the filter and the problem solved. https://www.ford-trucks.com/forums/newreply.php
