1995 ford bronco overdrive light just started flashing!!! - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 09-27-2005, 12:40 AM
deepbass deepbass is offline
deepbass is starting off with a positive reputation.
Exclamation 1995 ford bronco overdrive light just started flashing!!!
My overdrive light started flashing on my 95 bronco 5.8L not too long ago. When the light starts flashing the shifting gets very hard (rpms rise very high then shifts hard). I went to Aamco transmission the other day and got a free diagnostics test. The people over at Aamco transmission mentioned that they had a hard time getting my trucks codes. The computer in the truck was not responding to anything until they found a faulty code (code 452) insufficienct input from vehicle speed sensor. I also understand that there are two speed sensors. So there is now a possibility my computer in the truck is messed up or the sensors are acting up. This problem has been going on for several several months. I am very frustrated!!!!
CAN ANYONE HELP ME!! ALL THE HELP IS GREATLY APPRECIATED!!
Old 09-27-2005, 01:09 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
First off, get it fixed before it causes serious damage. The rebuild bill on an E4OD is about $2500.
Secondly, get it to a good transmission shop. Aamco is a rip-off joint, and more of their employees are incompetent than not.
If it is the VSS, then you can just take it out of the diff (one bolt holds it in) and wipe it off with a rag. They very rarely go bad. No moving parts to break.
Old 09-27-2005, 02:30 PM
McLeod McLeod is offline
McLeod is gaining momentum as a positive member of FTE.
Old 10-25-2005, 06:46 AM
PhilcoPGM PhilcoPGM is offline
PhilcoPGM is starting off with a positive reputation.
McLeod,
I went to NAPA for a speed sensor for my 98 F150 automatic. Had my tranny rebuilt 2 months ago and took it back because the O/D lite started flashing. The tranny shop put a scan tool on it and it showed code 452 which is an error in the VSS, so they told me I had to get it replaced. I want to do that, and I hear it's located in th erear differential;but exactly where? Does one bolt expose the old one or a series of bolts? And which side do I start to remove the cover; front side or back side? There's not too much on this site to explain where to find it. Thanks for all your help!
Phil
E40D problems Tom D Clutch, Transmission, Differential, Axle & Transfer Case 7 02-06-2016 09:29 AM
1994 f350 Intermittant blinking OD light, wont shift into OD 1wvboy 1987 - 1996 F150 & Larger F-Series Trucks 2 03-04-2012 03:10 PM
e4od problems (with codes listed) TradMercs 1987 - 1996 F150 & Larger F-Series Trucks 19 12-29-2010 11:05 AM
Code's bigrigmike Excursion - King of SUVs 28 07-11-2010 10:19 PM
95 ford bronco transmission overdrive light just started blinking!!! deepbass Clutch, Transmission, Differential, Axle & Transfer Case 0 09-27-2005 12:39 AM
Tags
1995, 95, bronco, codes, econoline, find, flashes, flashin, flashing, flickers, ford, light, lightning, od, overdrive
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
