Expedition moonroof issue
Hi Everyone,
Just joined to find out if my local Ford dealer is trying to rip me off. I have a 2000 Expedition EB w/ power moonroof that is stuck in the open position. Dealer says that switch,motor, and track are all bad which seems to me to be a statistical impossibility. Wants $2200 to repair. Also says that the moonroof cannot be just closed and disconnected.
thoughts, help? anyone?
Chris
Chris
Nothing in the owners manual. I checked, there is no access to the moonroof which is why it is so expensive. I am being charged $1200 for the removal of the ENTIRE headliner, and another $1000 for new motor and track.
Like your handle, another repair like this and I may change from haveaford to hadaford pretty quickly
Thanks
Thanks
on
1 Post
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...d.php?t=300691 There are also State Chapters located near the bottom of the main forum page.
That's too bad about your Expedition. I will move this to the Expedition forum where you will get more help.
See ya on the boards!
-Matt
-Matt
The headliner is easy! I have had mine out 2 times. The first time it took about 1 1/2 hrs to get it out. The second time it only took about 45 min. There should be an access in the headliner just behind the sunroof. It just clips into place. The motor is right under the access. But if not and you have to remove the entire headliner let me know.... I'll give you some advice. It's not as bad as it looks! Yes there are alot of peices to remove, but it's really not that bad!
TSB 03-11-10
FORD: 2000-2003 EXPEDITION
2001-2003 F-150
2003 SUPER DUTY F SERIES
LINCOLN: 2000-2003 NAVIGATOR
ISSUE:
Some 2000-2003 Expedition/Navigator, 2001-2003 F-Series Under 8500, and 2003 F-Series over 8500 vehicles may exhibit a rattle from the roof opening panel (moonroof) area, a failure of the roof opening panel to open properly, or a water leak from the roof opening panel. This may be due to the water trough being separated from the trough guide on either side, as a result of a broken trough guide.
__________________________________________________ _____________________
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TH vAlign=bottom align=middle colSpan=4>LABOR OPERATION CLAIMING CHART</TH></TR><TR><TH vAlign=bottom align=middle>Operation</TH><TH vAlign=bottom align=middle>Labor Description</TH><TH vAlign=bottom align=middle>Vehicle</TH><TH vAlign=bottom align=middle>Time</TH></TR><TR><TD style="BORDER-BOTTOM: medium none" vAlign=top align=left>031110A</TD><TD style="BORDER-BOTTOM: medium none" vAlign=top align=left>Inspect And Replace Roof Opening Panel Frame (Includes Time To Remove And Install Headliner)</TD><TD style="BORDER-BOTTOM: medium none" vAlign=top align=left>2000-2002 Expedition/Navigator</TD><TD style="BORDER-BOTTOM: medium none" vAlign=top align=left>2.1 Hrs.</TD></TR><TR><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left></TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left></TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left>2003 Expedition/Navigator</TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left>2.8 Hrs.</TD></TR><TR><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left></TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left></TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left>2001-2003 F-150 Super Cab</TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left>1.4 Hrs.</TD></TR><TR><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left></TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left></TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left>2001-2003 F-150 Super Crew</TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left>2.2 Hrs.</TD></TR><TR><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left></TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left></TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left>2003 F-Super Duty Super Cab</TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left>1.5 Hrs.</TD></TR><TR><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left></TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left></TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left>2003 F-Super Duty Super Crew</TD><TD style="BORDER-TOP: medium none; BORDER-BOTTOM: medium none" vAlign=top align=left>2.2 Hrs.</TD></TR></TBODY></TABLE>
2001-2003 F-150
ISSUE:
I hava 1999 Navigator , there is a moonroof/window vent RELAY located behind the driver seat, inside the side panel . Relay is a SPDT type which used several places in the Navigator. It switches power in and out to the moonroof and vent electronics, on my 1999 the 12v IN is on the red/blk wire, the switched 12v out is on the pink wire of the relay. Pull relay out, and supply 12V from the battery to the pink wire - (this supplies power to the moonroof/vent assembles). This will test to see if this an issue with power going to the assembles , it will also demonstrate the actions of the assembles onced enerigized.
fyi
fyi
2Fords1Jeep
1997-2006 Expedition & Navigator
32
10-11-2014 01:59 PM
