Clutch adjustment? - Ford Truck Enthusiasts Forums
Clutch adjustment?
Old 09-26-2005, 08:04 PM
wickymustang wickymustang is offline
wickymustang is starting off with a positive reputation.
Clutch adjustment?
I just had my rear main replaced on my 95 F150 with the 4.9 and the M5OD. When I got it back from the shop, they said they adjusted everything and lubed the shift fork after they dropped the tranny to get to the rear main. The only problem now is that it seems like the clutch pedal doesn't engage until almost the floor, like the last 1/5 of pedal travel. They said they didn't touch the slave so it shouldn't need to be bled, so is there some adjustment I can make so that I get engagement and disengagement at about 1/2 pedal travel where it is supposed to be?
Adjusting a hydraulic clutch?? Thoth88 Ranger & B-Series 3 01-14-2014 11:31 PM
Swapped from 435 to ZF5 - now clutch engagement issue K9spike Clutch, Transmission, Differential, Axle & Transfer Case 1 05-26-2012 12:00 AM
49 F1 Flathead V8 to T5 Comversion keystoneaz 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 07-05-2009 05:07 PM
ZF clutch adjustment? Wild Karrde Clutch, Transmission, Differential, Axle & Transfer Case 4 08-13-2007 11:05 AM
self adjusting clutch? bigdaddyII Clutch, Transmission, Differential, Axle & Transfer Case 5 02-26-2005 07:15 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
