ford lariat - wobble in rear - Ford Truck Enthusiasts Forums
Old 09-26-2005, 07:26 PM
caymanraymond caymanraymond is offline
caymanraymond is starting off with a positive reputation.
Should the rear wheels turn when the truck is on jack stands and is in park.
Old 09-26-2005, 07:58 PM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
Hi and welcome to FTE! Be sure to read this to help you around this site: http://www.ford-trucks.com/forums/sh...d.php?t=300691 There are also State Chapters located near the bottom of the main forum page.
I am assuming you are asking about the 97 F-150 in your profile so I am moving this question to the 97-2003 F-150 forum. And yes the tires will turn when in park and up on jackstands.
See ya on the boards!
-Matt
Old 09-26-2005, 09:15 PM
Thanks a lot. For the info. All of the front joints/arms etc was fixed a couple of weeks ago, new tires all round, this evening a fairly bad vibration started from the back. There is some play in the wheel when shaken up on stands. Anyhow I guess it's back to the shop tomorrow.
Rear Sway Bar: 79Supercab 1973 - 1979 F-100 & Larger F-Series Trucks 1 02-11-2015 05:14 PM
full sliding rear window` SnowHiker 2004 - 2008 F150 10 05-18-2012 01:21 PM
rear brakes turbo740922 1997 - 2003 F150 0 01-06-2010 05:31 PM
46/47 truck rear bumper magicbus 1947 and Older Ford Trucks 1 01-05-2009 10:10 PM
diff. in rear ends rodney 1967 - 1972 F-100 & Larger F-Series Trucks 4 10-23-1999 05:53 PM
Tags
rear, truck, wobble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
