Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-26-2005, 02:02 PM
olthunter olthunter is offline
Garage is empty, add now
olthunter is starting off with a positive reputation.
ignition system
i have a '46 flathead, 59AB, and was wondering what the best way to go is with ignition. i don't know yet if i'm going with a 6 volt or 12 volt, but know speedwaymotors has the dual point distributor with a new coil that can work with a 6 or 12 volt. my question here is my budget restoration is for a driver, not a street rod, so would a newer ignition system make that much difference? a rebuilt distributor is around 150 and the one from speedway is 250, so would the 100 bucks be worth it? any input, opinion, or experience would be appreciated. thanks for your time.
  #2 (permalink)
Old 09-26-2005, 04:49 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.
The stock ignition in a stock motor works fine.
If you Hop Up the motor, a hotter ignition is required to get the full benifit.
__________________
Dick C
Erie, PA
1948 Ford F1 Panel
1952 Ford F2 (Non-Stock Flat 6)
1997 Ford Explorer
Every Thing I've Ever Said Is A Lie
  #3 (permalink)
Old 09-27-2005, 08:17 AM
51ford fan's Avatar
51ford fan 51ford fan is offline
51ford fan is starting off with a positive reputation.
Check out this link; some of the guys over on the Jalopy Journal are converting Mopar distributors to use in Flatheads. Most posts are for the 8BA, but there is one on the 59A, it's using Mopar guts in the stock unit
http://www.jalopyjournal.com/forum/s...ad.php?t=64765
Rod
  #4 (permalink)
Old 10-16-2005, 08:55 PM
51frrdtrk 51frrdtrk is offline
51frrdtrk is starting off with a positive reputation.
Save your money and stick with the stock distributer and convert over to 12 volt. I played with 6 volt for years and finally switched. Now i hit the starter and she starts every time.
__________________
CRASH
  #5 (permalink)
Old 10-16-2005, 11:52 PM
46fordtruck's Avatar
46fordtruck 46fordtruck is offline
1946 Ford 1/2 ton pickup
46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.
By the way, the stock distributor is dual point in the 59AB. Follow like said, if you are leaving the motor mostly stock, then stock should do you well. Remember, millions of these motors were made, and most saw daily driver use with the stock distributors. If you decide to add more HP to the motor, then upgrade to a newer ignition...when I start hopping up my flatty I'm going to add a Mallory elec ignition, until then, sticking with stock.
__________________
Gary-
'46 Ford 1/2 ton
'07 Black F-150 XLT SuperCrew
plus a handful of other Fords
'42-'47 collector and aficionado
Tags
1948, 59ab, flathead, hop, ignition
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
