09-26-2005, 03:38 PM
Just my .02, but I would let the pro's handle this one. One of my customers in Knoxville,Tn., makes the containers that hold the connections, and the explosives that deploy the airbags. Those things are dangerous, and if it goes off while you are tinkering with it, you may live to suffer the consequences. Those cylinders are tested to 10,000 psi in a special machine, and when one fails the test sequence, it sounds like a small bomb went off. Not to mention, if all goes apparently well, no lights or anything, and you crash again(God forbid) and it doesn't work, well you said the last one saved your life, I would want to know that it was right.Again, just one man's opinion .
__________________
Psalm27:1
