Brakes Squeek in reverse - Ford Truck Enthusiasts Forums
Old 09-26-2005, 10:24 AM
Fxxer Fxxer is offline
Fxxer is starting off with a positive reputation.
I have an 03' FX4 Screw and I put new pads and rotors on all 4 corners at 41,000 miles and now with about 45,000 on it when I back out of my driveway the brakes have a squeel to them when applying then releasing the brake(only in revearse) When driving around town no squeeking and they stop great. I don't think I have any problem but I was wondering if there was a linkage or something I could lube for this to stop.
Old 09-26-2005, 11:02 AM
lancekilgore lancekilgore is offline
lancekilgore is starting off with a positive reputation.
sounds like there is just some brake dust stuck in there. take some brake cleaner and spray the rotors while you turn the hub. (wheels off and jacked up) if that clears it up then that is all it was. If it comes back after another 4 or 5 thousand miles then they are not very good brakes.
Lance
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
