1999 Ford F-150 ignition timing - Ford Truck Enthusiasts Forums
Old 09-26-2005, 09:15 AM
grove00 grove00 is offline
grove00 is starting off with a positive reputation.
I have a 1999 F-150 4x4 with 93000 miles and a 4.2l v6. I started noticing a decrease in power, rough idle and engine hesitation at 30-40mph. Also, fuel mileage has decreased considerably. I checked it with a Snap-On diagnostic scanner and found the ignition timing to be 22 degrees advanced at an idle. Upon acceleration, the timing went negative when I reached 55mph. This can't be correct. I took the truck to a dealership but all they did was check to see if there were any codes in the computer and tell me that there was no problem(never go back there again). I did have them change the fuel filter while they had it. Any ideas? What is the correct timing for this engine?
Old 09-26-2005, 10:12 AM
lancekilgore lancekilgore is offline
lancekilgore is starting off with a positive reputation.
I don't know what the corrrect timing should be but you must understand that the main cpu in the truck changes the timming as it needs to ( to where it feels it should be to run the best). Did you try a tune up new plugs fuel filter air filter ect. couldn't hurt unless you did one recently. I think they can put a chip in it to manually change he timing. I don't know much about that though. Some one will chime in if I am wrong. Good luck
Lance
Old 09-26-2005, 11:31 AM
mr_muldoon mr_muldoon is offline
mr_muldoon is starting off with a positive reputation.
I would check that the knock sensor is properly torqued and functioning. A loose or malfunctioning knock sensor can cause false retard, or worse, false advance.
Old 09-26-2005, 06:24 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
Quote:
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
97 F150 4.6l starting issue Penton97F150 1997 - 2003 F150 8 06-26-2016 10:49 PM
97 F150 4.2L Engine Cooling Fan tigertail222 1997 - 2003 F150 3 02-07-2011 01:42 PM
534 Firing order ? Robvan 401, 477, & 534 SD Engines 6 06-10-2008 10:25 AM
in need of carb swap info please! oregonian 1978 - 1996 Big Bronco 5 11-01-2003 08:24 PM
93 F150 Shudders on acceleration texa5 1987 - 1996 F150 & Larger F-Series Trucks 9 10-24-2003 06:19 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
