Need some help, guys...
My daughter's 1989 Ranger with a 2.3L started leaking antifreeze this past week. I got under it and finally found the leak...headgasket at the right front corner.
So...I begin the procedure of replacing the head gasket. I have the exhaust manifold, intake, timing belt, yadda, yadda, yadda off. Now here is my problem.
I don't have a 8 point 13 mm socket for the gead bolts. I substitute a 1/2 8 point and crank the right front bolt 1/4 turn (like the book says to), and move to the left front bolt. I can't get the socket on the bolt...there is some type of notch machined into the head. Is there a special socket that I need? Where would I procure one?
on
I just took a quick peek at my books, they say nothing about your problem. Obviously you have the Haynes manual, since they give that 1/4 turn incremental bolt removal procedure. Huh. The Chilton's just says, "Remove the cylinder head attaching bolts."
Usually, you can get by with substituting 1/2" for 13mm, they are so close. I just can't picture the interference problem you describe. Any chance you could take a pic and post it? Do you have a digital camera?
I have an earlier 2.3 at work, I'll take a look at it tomorrow. It's an '86, so I don't believe they're quite the same but I'll check.
I think that you have to have a thin-walled socket fit into the notch around the headbolt. If you are using a less-expensive brand of sockets, they will sometimes substitute more metal for strength, thus the thicker walls. Go to your nearest store selling quality sockets, carrying your 1/2" for comparison. I expect you will see the thickness at the business end to be significantly thinner on a 'high-priced' tool.
If memory is working (hah), it seems to me that I had no problem using a Craftsman socket on my 2.3. Of course, I didn't remove the head, just drained coolant, loosened the head bolts, and re-torqued them. I had a slight oil leak at the rear of the head, where the oil comes up around the driver side rearmost head bolt. I figured it couldn't hurt to re-torque the head bolts, and it worked.
tom
tom
phatpharm85
30
11-24-2003 09:23 PM
