2004 & UP Hood Protectors
I began to install a Stampede 3132 on my 2005. The "Sandwich" of the grill and the protector was to say the least, unimpressive. There are some areas that fit well and some that no matter what I did would not line up the same. Is there any protectors being made that has a better way of mounting than this? I got this one beacause it was to be easy on the hood as to rubbing the paint. Anyway, it now lives back in the box it came in as I am looking for another. Thanks-Keith
You might want to look at 3M automotive products. They make a clear urathane tape type product which is applied directly over painted areas to protect against damage. Many to the OEM's are using this for lower fender areas behind the tires. It is inexpensive (relatively) and you can install yourself or go to one of their installation centers.
Got an "autoventshade" model. It too sandwiches between the grill and hood. I installed it in just a few minutes with out any problems. Had to adjust the two lower hood bumbers though. No problems with fit and plenty clearance around all surfaces and hood. Easy to clean behind and no fear of rubbing the paint unless I wreck it!!
I think they all install with this same system. key words here " I think". I have seen ones on other vehicles installed witrh that 3m brand tape and they always seem to eventually start peeling off.
When I first saw how this intsall worked I wasn't crazy about it either. when it's all said and done I am real happy with it because it's very secure and I didn't have to drill and holes or use and plastic fasteners that always get loose.
maybe just try another brand. bought mine at advance for about $50 in august of 2004.
