Open Differentials - Ford Truck Enthusiasts Forums
Open Differentials
Old 09-25-2005, 01:33 PM
zman764 zman764 is offline
zman764 is starting off with a positive reputation.
Open Differentials
Is there any affordable, easy to do, reliable way to upgrade open differentials too anything else?
Old 09-25-2005, 02:12 PM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
What do you want? LS or a locker?
You could always weld up the spider gears...but I would highly disregard this unless its an offroad truck only.
Old 09-25-2005, 04:00 PM
BLK94F150 BLK94F150 is offline
BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.
Lunchbox locker for the rear like a Lock-rite.
Mike
Old 09-25-2005, 04:31 PM
CanadaGuy CanadaGuy is offline
CanadaGuy is gaining momentum as a positive member of FTE.
Quote:
Ahhhh.... the "Lincoln-Locker"... also known as the hillbilly locker.
Old 09-26-2005, 05:09 PM
I would like a locker, but i do to much highway driving and think i would be better off with more like a limited slip. I dont want to weld.
differentials pros cons 1972fordhighboy 1973 - 1979 F-100 & Larger F-Series Trucks 2 11-23-2014 08:26 AM
F350 DRW Differential bobert2412 6.7L Power Stroke Diesel 0 02-23-2011 05:34 PM
98 ranger differential service kdeleon Ranger & B-Series 13 08-27-2006 08:47 PM
Friction Modifier In Open Differential DudesRUs Clutch, Transmission, Differential, Axle & Transfer Case 3 01-13-2005 01:12 PM
Traction lock vs. open differential gray79f250 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-20-2002 08:57 PM
Tags
differentials, duty, f150, ford, open, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
