why - Page 4 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
why
  #46
Old 09-28-2005, 12:47 AM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
Just because an engine has single or twin turbo's means beggar all in terms of fuel consumption.
BMW put twin turbos on thier 3liter diesel engine, and fuel economy improved.
What does that mean? Not a lot.
BTW. BMW actually poineered using the sequential turbocharging on diesels (initially developed by Mazda for its RX-7).
If you want an interesting read. Do a "google" on BMW 535d.
  #47
Old 09-28-2005, 09:45 AM
Bar L Bar L is offline
Bar L is starting off with a positive reputation.
Not for sure if it was the NASCAR truck, but it was a racing truck, it was sitting right there with the 6.0 in it and he said it had performed well on the track.
  #48
Old 09-28-2005, 08:39 PM
machanic machanic is offline
machanic is starting off with a positive reputation.
Answer this? are you guys sure that this is a 4 egr system, or a four port single egr like the ones gm uses on thier autos.
  #49
Old 09-28-2005, 09:44 PM
SpartanDieselTech's Avatar
SpartanDieselTech SpartanDieselTech is offline
Former Vendor
SpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to all
Quote:
I certainly could be wrong on this but I'm with you on the guess; I'd say its a single valve with a multi-port (4) entrance into the intake manifold.
  #50
Old 09-28-2005, 10:34 PM
dPrasse01 dPrasse01 is offline
dPrasse01 is starting off with a positive reputation.
Quote:
Originally Posted by ford390gashog
were issues with Ford's software programs (however since worked out), not the Navstar engine
other way around. its navistars software problems.
Not from everything that I have read ... Ford did not buy the "complete" engine package ... just the hardware ... the International 6.0s with the "complete " Intenational engine package are not having the same probs as the Ford 6.0 ....
  #51
Old 09-29-2005, 11:31 PM
Former Vendor
Oh no, Ford is the one that dropped the ball as far as electronics are concerned.
The faulty EGR valves and faulty EBP, ICP sensors....International's responsibility.
  #52
Old 10-02-2005, 01:11 AM
sparke454 sparke454 is offline
sparke454 is starting off with a positive reputation.
what is an lcf?
  #53
Old 10-02-2005, 08:51 AM
bnmccoy's Avatar
bnmccoy bnmccoy is offline
bnmccoy is gaining momentum as a positive member of FTE.bnmccoy is gaining momentum as a positive member of FTE.
LCF is Low Cab Forward IIRC, if I recall correctly.....
Boxy looking delivery trucks that Ford and International along with others manufacture.
Bob
  #54
Old 10-02-2005, 09:40 AM
barebackjake's Avatar
barebackjake barebackjake is offline
barebackjake is starting off with a positive reputation.
the twins are able to keep boost up thoughout the whole rpm range which makes it burn fuel more effecently. if the 6.4 is anything like the 4.5 thats in the LCF i would even think about buying one. well maybe not i love my 97. im looking at buyin a LCF for work though.
  #55
Old 10-06-2005, 11:32 AM
ChunkyP ChunkyP is offline
ChunkyP is starting off with a positive reputation.
The only bad thing about twin turbos is if one goes out so does the other one. Replacing one is bad enough but two, ouch.
  #56
Old 10-09-2005, 11:49 PM
MW95F250's Avatar
MW95F250 MW95F250 is offline
MW95F250 is starting off with a positive reputation.
Quote:
Originally Posted by Stroker_Deezel
As far as i know, the Dmax will meet emmisions into the future, and i dont know anything about cummins and emissions
They have lowered compression to 17.5:1 IIRC to meet emissions and keep the head gaskets intact....
  #57
Old 10-09-2005, 11:53 PM
MW95F250's Avatar
Quote:
The standard Nascar engine block is 358 ci, which happens to be 6 Liters if you round up.
The Ford 6-Liter diesel is 365 ci.
  #58
Old 10-11-2005, 06:49 AM
NickFordMan's Avatar
NickFordMan NickFordMan is offline
NickFordMan is gaining momentum as a positive member of FTE.
Is it going to be efficient? You can bet your bottom dollar. I want to know about the EGR's as well, and if there would be a possibility to disconnect them.
  #59
Old 10-30-2005, 11:36 PM
handyman43358's Avatar
handyman43358 handyman43358 is offline
handyman43358 is gaining momentum as a positive member of FTE.
I will start of by saying that I have been a Ford man all my life. I probably won't ever own anything else. But I ponder this question. Why all the changes? In the diesel department, Ford went from the 6.9 to the 7.3, then the 7.3 turbo, then the 7.3 powerstroke, to the 6.0, and now the 6.4. God knows what all chevy has been through diesel wise, dont know dont care. Now lets look at Dodge. 5.9L Turbo since like what? 1990? The only change in this diesel was 12 more valves. I like cummins, I like Ford, I hate dodge. I think Ford needs to grab ahold of cummins and allison trannys. That would be the BEST truck in the world.
  #60
Old 10-31-2005, 01:06 AM
hercules130 hercules130 is offline
hercules130 is starting off with a positive reputation.
I don't know why you guys bash dodge trucks, i just bought one (last march)and the quality is outstanding. no shakes, rattles or trim peices falling off. the truck has been flawless and i love the 6 speed. i do wish the cummins were louder, but what can you do. i had every intention of buying a ford, but after driving the dodge, there was know way i would get the ford. i could write a page on why i wouldn't get the ford (for my needs) but i don't want to bore you all with that.
Why? Clifford Petersen 6.0L Power Stroke Diesel 6 12-06-2016 01:09 PM
Egr delete. Newbie Jordo88 6.0L Power Stroke Diesel 7 09-11-2015 02:46 PM
why would they replace the 7.3 with the 6.0 bftchamp 1999 - 2003 7.3L Power Stroke Diesel 4 03-29-2015 10:03 PM
Ford 6.0 diesel horsepower Tom Callan 1968-2013 Full Size Vans 2 01-29-2015 05:12 PM
6.0 in a world of Hurt!!!!!! FortyFords 1999 to 2016 Super Duty 45 03-10-2005 11:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
