Losing Brake Fluid on a 1994 F150 - Ford Truck Enthusiasts Forums
Old 09-24-2005, 09:15 PM
NF29 NF29 is offline
NF29 is starting off with a positive reputation.
I am having to add brake fluid way more than I should be on my 1994 F150. There are no leaks around the master cylinder, or on any of the fittings that are visible under the hood. Where should I start looking for the leak.... What are the usual places that start to leak on this truck.
Thanks
Old 09-24-2005, 09:25 PM
924x2150's Avatar
924x2150 924x2150 is offline
924x2150 has a good reputation on FTE.924x2150 has a good reputation on FTE.924x2150 has a good reputation on FTE.
Why not trace all the lines from the master cylinder to each wheel. if it is a line it is most likely be coming from the rubber coated flex line near the wheels.
The calipers on the front...check for any oily stuff coming out of the caliper piston, unfortunately, you may have to remove the brake pads and caliper to get a good look. If it is leaking bad you might notice it if you take a good long look while under the front end.
If the rear is leaking, you proabably need to pull the wheel and drum off the truck. The brake cylinders are mounted inside the drum and can leak out either end.
Loss of any brake fluid at all is unacceptable, whether it is leaking out or boiling out, I honestly can't say which is scarier. It is something that needs attention ASAP.
PS My 92 brakes are still original stock, except the rear brake cylinders, they leaked and have been replaced with new ones, they are 10 US dollars each
Old 09-24-2005, 11:05 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is online now
bigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to behold
Are you still able to use your brakes? If there is a leak and no air is being introduced into the system one of the most common places is the rear wheel cylinders. Look under your truck at the inside of the back tires, if they appear wet, than you need to invest in some wheel cylinders and brake shoes.
Old 10-20-2005, 06:35 PM
Jimi62 Jimi62 is offline
Jimi62 is starting off with a positive reputation.
If it has drum brakes the wheel cly can leak a long time before you can see it on the out side. Watch for wet dirt looking on back plate and wet inside tire when its real bad.
Old 10-20-2005, 08:47 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
I would definitely check it out ASAP. Like everyone else says, you need a thorough inspection done to find the leak. If you can't find it anywhere, the master cylinder can leak into the brake booster. If that's happening, you need to replace the master cylinder and the booster.
Old 10-20-2005, 10:15 PM
51frrdtrk 51frrdtrk is offline
51frrdtrk is starting off with a positive reputation.
If you can;t find an external leak on the lines or wheel cylinders. Pull the vacume hose off and see if its wet inside, if so the master cylinder is leaking and should be replaced.
Rear brake grabbing ? ncranchero 1987 - 1996 F150 & Larger F-Series Trucks 4 02-06-2016 04:46 PM
Brake fluid? Tranny Fluid? Curtis Gruman 1994.5 - 1997 7.3L Power Stroke Diesel 9 10-30-2015 11:08 AM
Neutralizing brake fluid Plum 1987 - 1996 F150 & Larger F-Series Trucks 3 02-20-2014 09:05 PM
what parts do I need for a brake job on a 1994 Ford F150 4x4 mrslatham 1987 - 1996 F150 & Larger F-Series Trucks 1 02-24-2013 08:02 PM
Brake Fluid flhr 2004 - 2008 F150 14 02-04-2010 11:12 PM
Tags
1994, 94, brake, cylinder, f150, fluid, leak, leaking, leaks, losing, rear, visible, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
