Shifter STUCK in Park - Ford Truck Enthusiasts Forums
Old 09-24-2005, 03:12 PM
Scorpion_DvT's Avatar
Scorpion_DvT Scorpion_DvT is offline
Scorpion_DvT is starting off with a positive reputation.
Question Shifter STUCK in Park
I got home from Louisiana last thursday nite, was gone for three weeks serving for the National Guard down there, I went to drive my truck and the shifter wouldn't ger out of Park. It finally went, I thought it was maybe a freak thing, but now it gets stuck all the time, but once it's out of Park it shifts through ever gear smoothly. It feels like something in the column. Does anyone have any idea what it may be and it's a pretty simple fix?
If anyone has any ideas I would really appreciate it, thanks.
Old 09-24-2005, 03:22 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Sometimes it is the column lock mechanism that puts everything in a bind. Try turning the steering wheel slightly.
Old 09-24-2005, 03:35 PM
I tried that, but sometimes that doesn't work...actually most of the time it doesn't work, I just keep playing with the shifter until it does. I'm just wondering if it may be a part that I can get and replace in the column.
Thanks anyway Torque
Old 09-24-2005, 04:22 PM
triton_2002's Avatar
triton_2002 triton_2002 is offline
triton_2002 is starting off with a positive reputation.
There's a safety switch on the brake pedal that might be bad or loose connection.
Old 09-25-2005, 09:33 AM
Yeah, I was thinking about that too....does anyone know where the safety switch is located, and if there is a way of testing it? If I can locate it, I just might buy a new one and replace it.
Old 09-25-2005, 10:12 AM
lancekilgore lancekilgore is offline
lancekilgore is starting off with a positive reputation.
there should be two switchs on the brake one for the lights and one for the shifter check them both it may be very simple and be a wire come off or a miss adjusted switch. they are easy to check with a multimeter put it on ohms and psuh the switch in manually then check both ends for continuity if there is continuity then the switch is good if not then the switch is bad. I bet it is either unpluged or not making a good connection ore a broken wir though.
Lance
Old 09-25-2005, 12:43 PM
lariat97's Avatar
lariat97 lariat97 is offline
lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.
My 96 did this & it was the trailor light fuse blown. It also controls the safty switch on the shifter. I blew the fuse backing my boat in the lake without unhooking the lights. Its in the underhood fusebox.
Old 09-25-2005, 02:53 PM
Thanks guys, I'll check the fuses and make sure it's nothing simple like that. It's just weird, I'll put in Park, then it just takes some fiddling with the shifter, it will finally go, it just seems like something is catching on the steering column itself, then after playing with it for a while it'll finally shift out of Park. For now, I just basically put in Nuetral, shut the truck off, then slide it into Reverse and put the E brake on and luckily because my key is worn out a bit, it comes out of the ignition, and the shifter only gets stuck on Park, not anywhere else...
Old 09-25-2005, 03:04 PM
PaulC PaulC is offline
PaulC is starting off with a positive reputation.
Scorpion:
First verify that the brake lights are working, as sometimes their failure and the problem you're experiencing are related. Now, to get the truck out of Park:
With the key in the ignition, turn the key forward enough to release the mechanical shift lever/steering wheel lock, but not so far as to light up the dashboard, which will energize the electric shift lever/brake pedal interlock. Shift into neutral, start engine. You will have to repeat this drill everytime you need to shift out of Park, even if the engine is running. Again, check the brake lights before you drive the truck again.
Old 09-25-2005, 05:38 PM
BlueOvalFitter's Avatar
BlueOvalFitter BlueOvalFitter is offline
BlueOvalFitter is gaining momentum as a positive member of FTE.
Your BOO (brake on/off) switch is either bad or one of the wires to the connector to it is broken.Mine did the same thing.It was a broken wire. It is located on your brake pedal lever under the dash.
Old 09-25-2005, 07:27 PM
Smaug's Avatar
Smaug Smaug is offline
Smaug is starting off with a positive reputation.
The cruise control deactivation switch can also cause this problem. This is the same switch that is causing the latest recall. Ford is not replacing the switch though, they are putting a different harness in.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
