Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 09-24-2005, 10:44 AM
rcain1 rcain1 is offline
Garage is empty, add now
rcain1 is starting off with a positive reputation.
BioDiesel User/Maker in Killeen, Texas
I know that the topic of "BIODIESEL" is all over this forum and I have done some looking and reading about it (here, at biodiesel.org and other internet sites). I was kinda hoping to talk with a forum user who is local to the Killeen/Coppers Cove/Harker Heights area. I am a normal guy, I don't have any engines hanging from my trees or transmissions in any of my bath tubs.
Here is what I want to know:
~How it has worked for you and your vehicle as far as:
~cost and savings vrs diesel
~has it jacked-up your engine
~do you need a METH LAB look-alike setup
~If you have been using it are you willing to help me get setup to use it?
I hope to hear from a fellow diesel user. Thanks!
__________________
99' F-250 Super Duty 4X4
Front & Rear Bumper replacement
K&N Airfilter
Rhino Liner
1705 chip tuner
Front End Leveling Kit
  #2 (permalink)
Old 09-24-2005, 11:35 AM
kregars kregars is offline
kregars is starting off with a positive reputation.
I am also looking to start brewing my own 'juice' or as I will be referring to is as an 'additive' in mass.
I have made small batches (less than 5% per tank) and noted it's very simple..the hardest part (for me) is the titration (I was horrible in chemistry..infact..withdrew failing both times in HS, and Passed (due to extra credits ONLY) in College...my math skills however are helping to comensate.
There are many resources avail online. The basics are simple. You supply a reactant, source of heat, and then (for stovetop production) settle it to allow glycerine and any residing water to seperate.
I am looking at using the appleseed processor (have most of the parts either on hand, or ordered (hot water heater element for 110 was the hardest to locate..ended up buying online).
I dont yet have MY truck (looking to HOPEFULLY find one today..wish me luck), but from what I have read, there are MANY that are running home-brew 100% without negative affects. Some have been running it since new (2003.4 and below to 2001), others have converted over for their earlier models (94-). The ONLY complaint I have seen is that people forget to have spare filters at the ready as BD can and WILL 'clean out the fuel delivery system from tank forward' and their trucks die on teh side of the road due to clogged filters.
I have been running ~5%BD in my TDi for a while..moreso to get the positive affects of BD (lubricity is fantastic, as well as the higher cetane). In the winter I still run DK Winter additive...but that's because I can be sent from here in the DC metro area to Boston...and I may use merely half a tank of fuel, and need to ensure it wont gell/wax over the road.
As for the Meth Lab look....I honestly dont know what one looks like, but as long as you take precautions, you should be GTG....I would recommend using a methanol recovery process instead of straight venting to the outside (this will also reduce your costs overall), this will make it more 'treehugger' acceptable as well.
If your local authorities ask...show them your setup....you may be suprised. Many local authorities dont care..so long as if you're making your own fuel you are paying the taxes on it...if your making a fuel additive, you may or may not need to pay overroad taxes to your local and federal friends...check with your local offices to find this out.
I'd suggest making your first several batches to play with and get used to handling the chemicals....you need minimal things...BUT..SAFETY FIRST.
Get a GOOD respirator..preferably one that has the ability to have an outside air inlet adapted so you are getting fresh air from OUTSIDE...Methanol in the body forms fermaldihide(sp)...you dont wnat to embalm yourself trying to make fuel.
Safety goggles...ones that COMPLETELY protect your eyes...nod just those over the ear things you buy for working with wood...spend the extra 5 bux to get chemist goggles....and yes..Home Depot DOES sell them.
Chemical safe gloves..buy them...again...Methanol can and is absorbed by the skin...no embalming while making fuel..that's what I would call Bad(tm).
Wear full overclothes..and have an emergency shower and eyewash station..these are SIMPLE to build...and a must.
To be honest...the entire safety setup cost MAYBE 100bucks...but 100 bucks is better than pushing up flowers.
I will try to get some pics together of my emergency wash station..but it consists of simple materials...and can be triggered quickly for both full shower, and eyewash or just shower..or just eyewash.
Good luck...it's a fun experience to have a hobby, but just ensure your playing safe.
__________________
Bone stock 1994 Ford Explorer XLT, power windows, power locks, maint above and beyond the call of duty only 44k miles since new.
  #3 (permalink)
Old 09-26-2005, 01:26 PM
thanks kregards
Thank you for the info.
There is nobody local?
__________________
K&N Airfilter
Rhino Liner
1705 chip tuner
  #4 (permalink)
Old 09-26-2005, 09:05 PM
bczolone's Avatar
bczolone bczolone is offline
bczolone is gaining momentum as a positive member of FTE.bczolone is gaining momentum as a positive member of FTE.
sorry not local, but I am making it also; its kind of fun actually, but I teach chemisty. No I wont run it in my new 6.0 because of injector issues. I have ran 10+ gallons through a tractor and pressur washer, worked great so far.
  #5 (permalink)
Old 10-08-2005, 08:53 PM
Bigham's Avatar
Bigham Bigham is offline
Bigham is starting off with a positive reputation.
I would like to know if there is anyone in NJ who makes Biodiesel that I might be able to meet with and have a beer with. So that i can pick their brain.
Thanks
Eddie
Central Jersey
Tags
bio, biodiesel, biofuel, diesel, disiel, killeen, killen, maker, maths, tas, texas, tx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
