You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
For those that require it, DonsFx4 has converted his 04 F150 to have amber turn signals (instead of the usual brake light turn signal combo).
I know these are required in Australia, New Zealand, Britain, and most European countries, so if anyone is thinking of importing an F150 this has to be done.
Did the same on my 2000 Excursion to pass the SVA (Single Vehicle Approval) test here in the UK.
Easy way is to run feed for the turn signals from the fronts and get a clean brake feed from the high level brake light.
Also had to add side repeaters to the front fenders (below the ex' badge) to pass the test.
Hard part is finding the feed that makes the tail light/brake light repeat and disconnecting it but after an hour or so of trail and error BINGO!!
Low level reversing lights are slimline fogs., very bright even with the normal reverse feed and no relay.
UKS
I've done the same for my Bronco except for the repeaters on the fenders as I don't need them for a 92 vehicle (no SVA). Not bothered with reverse lights yet.... one day.
Simon
__________________ Proudly supporting US Ford Trucks from the little island across the Pond. 1992 Ford Bronco 302 E4OD Auto Eddie Bauer
1995 Vauxhall Omega 2.5TD CDX Auto
Founder, Staffordshire Search & Rescue Team, UK.
