Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-23-2005, 01:36 PM
Steve_B's Avatar
Steve_B Steve_B is offline
Garage is empty, add now
Steve_B is gaining momentum as a positive member of FTE.
Gearbox ID
Hi
Can anyone identify this Gearbox or should I say transmission
http://www.ford-trucks.com/user_gall...&albumid=10233
It came with my South African 1954 F100 and sat behind a 8BA flattie
Cast in the side is:
T87D-1H
WC DIV
Stephen
  #2 (permalink)
Old 09-23-2005, 07:19 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Hi Steve, the T87D is the HD 3 spd. Synchronized in gears 2 and 3. Spur gears in 1 and R. Not a bad trans for daily driving behind a flathead. That's what I'm using in my daily 48.
It rugged - bulletproof, even. I've been trying to wear this one out so I can go with on OD but it still looks like new inside after 4 years of daily use. (I just had the top off the other day) Parts are available from a variety of suppliers including Sacramento Vintage Ford.
Was your's in an industrial application? Mine has a driveshaft yoke that is attached to the output shaft.
  #3 (permalink)
45ford's Avatar
45ford 45ford is offline
45ford is starting off with a positive reputation.
Stephen:
It's the "heavy duty" three speed, available since at least 1948.
Mike
  #4 (permalink)
Old 09-24-2005, 12:17 PM
Steve_B's Avatar
Thanks 45ford & Mtflat
Quote:
This was in my 1954 F100, the propshaft bolts up to a square flange
Stephen
Tags
box, ford, gear, gearbox, id
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
