2005 FX4 5.4 Spark Plugs..?? - Ford Truck Enthusiasts Forums
Old 09-23-2005, 01:20 PM
Sliver Doug Sliver Doug is offline
Sliver Doug is starting off with a positive reputation.
Smile 2005 FX4 5.4 Spark Plugs..??
I was told If you change your plugs to the spark plug PZT-1-FF4 on your 2005 5.4 V8 It would increase your power And MPG..?? has anyone done this change..?? If so what was the improvement..?? Thanks, Doug
Old 09-23-2005, 02:41 PM
aquaman aquaman is offline
aquaman is gaining momentum as a positive member of FTE.aquaman is gaining momentum as a positive member of FTE.
I don't see how sparkplugs can increase mpg or power as long as your emissions are still good.
I did hear some rumors from another forum that Ford replaced the standard stock plugs with a different part number (maybe the one you listed) for some reason. Dunno if that was to address rough idling instead...
Old 09-23-2005, 06:01 PM
Ruckus Ruckus is offline
Ruckus is starting off with a positive reputation.
There is a fellow on here that has or had some magic spark plugs. He claimed 100 additional horsepower with them. I think he goes by 73Mach1. Good Luck!
Old 09-23-2005, 10:05 PM
xtrm1stang xtrm1stang is offline
xtrm1stang is starting off with a positive reputation.
Ford does have a message for tech's to replace the spark plugs with the new part number due to a misfire issue, but you are not going to be able to take it to a dealership and ask them just to replace them, there has to be a proble first. Most of your newer 2005's have the new plugs in them already.
Old 09-24-2005, 12:16 AM
73mach1 73mach1 is offline
73mach1 is starting off with a positive reputation.
yes i have them 112hp plugs made by roush.
the new plugs are the same as the new mustangs they were changed when i had the s/c installed cant remember if he said it was a hoter or colder plug. have u seen what the new style plugs look like?
Old 09-24-2005, 11:20 AM
silver-gt-vert silver-gt-vert is offline
silver-gt-vert is starting off with a positive reputation.
Quote:
Old 10-02-2005, 03:08 AM
BLariat BLariat is offline
BLariat is starting off with a positive reputation.
Well, spit it out man? What is the new part number for the plugs?????
New from Arkansas malllardhuner New Member Introductions 0 03-27-2015 10:32 PM
what color is the powerband? kdhannink 1967 - 1972 F-100 & Larger F-Series Trucks 17 05-10-2013 12:13 AM
460 bellhousing zzmark International Region 1 04-01-2007 12:13 AM
Thin Head Gaskets jokerforever Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 04-30-2006 09:02 AM
Brake pliers What is the one end used for? 66gpw Garage & Workshop 6 02-01-2005 06:54 PM
Tags
2005, change, ford, fx4, plugs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
