how to...reverse lights on a '48
You coluld position an external momentary contact pushbutton on the floor of your truck. Locate it in position where the shifter would come in contact with it when you shift it into reverse. If you built a sturdy housing for the switch it should hold up. I think they had this kind of switch on the old VW bugs back in the '60s.
Not familiar with the configuration of a T-98 is it a top or side shift box? In any case a microswitch should be able to be rigged like bobj said, use it to trip a relay to turn on the lights. Easier yet, just use a manual (dash?) on-off switch to turn them on and off when you need light to back up.
Please, don't use a manual switch unless you also wire in a red light nearby to remind yourself that your back up lights are on. Your fellow drivers will appreaciate it. The cargo light on later Ford trucks had such an arrangement, and would work.
I have seen back up lights that had a mechanism mounted on the transmission that engage a momitary switch when the gear shift was in the reverse position and the key was on, or when the parking or headlights were on. Just like bobj said, except that I think it was on an older grain truck.
try this link http://www.parts123.com/parts123/yb.dll?parta~partsort~2 and click on the picture
if not go to macs antique auto parts and do a search
ok sorry link no worrkie ok thry this
http://www.macsautoparts.com/
then go to the truck cataloge and type in backup light switch might try for like a mustang and such too till you can find a pic i thought this one would work maybe D2ZZ-15520-A but can not seem to be able to get a link to it for yah
also go to ebay motors and type in backup light switch and back up light switch one with the space one with out and you can look at what you might be able to get there and maybe local if you know an application or let them let you look at there books
Sure enough, cb, looks like either C9TZ-15520-C or C7TZ-15520-B and both come with brackets. I expect they are for 4 speeds with different shift patterns - bet one of them works, and only $16 or $17.
Reamer, if you try one, please post back which one and where your reverse is on the shift pattern. I will give them a try when I am closer to getting mine on the road!
reamer
2004 - 2008 F150
05-04-2011 09:20 AM
reamer
10-21-2008 10:16 AM
reamer
12-17-2005 05:21 AM
