tie rod over knuckle conversion on a 77 F250
Has anyone upgrade their steering by using the tierod over the knucle set up? I am going to convert my hydraulic power assist steeing to a 78/79 style and I was looking at my truck last night and it looks like the drag link would touch the springs if it were over the knuckle.
The only advantage to the over knuckle tie rod setup is for rock crawlers, they don't have as large a chance of bending their tie rod when they smash their axle into a rock. Even at that a better option is to go to a true "hy-steer" setup where you have arms off of the tops of the knuckles that hold the tie rod and a lot of times this will be done with the tie rod behind the axle instead of in front. All that being said, if you don't plan to bash your axle into stuff you'll never have need for it.
TC-Countryboy
12-27-2018 03:48 PM
Rintin69
Offroad & 4x4
10-26-2006 03:25 PM
ford_nut
01-28-2002 09:03 PM
