My Quest For 30*! (*mpg)
#46
That's just it though. If you operate a 302 at WOT you're going to be running 95 - 100 mph. Or 5000 - 6000 rpm in a lower gear. Not good for longevity. I think the police might take a dim view of a truck going by at 30 mph with the engine running at 5500rpm also.
You cannot reach that first statement of not sacrificing performance and running a 302 at or near WOT. The premise of operating the engine at it's most efficient BSFC range is that the power output of the engine matches the task to be performed. You mentioned earlier that it takes 9hp to run a car at highway speeds. Therefore you will need a 10-12hp engine running at 80-90% rated power to be in the most efficient operating mode. A 4500 pound truck that is that underpowered would probably be dangerous if operated on the streets.
A 302 could reasonably be expected to make 200hp. At 80% output that's 160 hp. If it take 9hp to cruise at leagal highway speeds, how fast would you be traveling at a 160hp output? Also, you want the load of moving the truck to limit the rpm of the engine, not the gearing.
#47
on
Well then it seems to achieve this you would need to "turn off" cylinders and run two cylinders at 80% o/p at hiway speeds. Cadillac used to do this(poorly) and Chrysler does it now with the new Hemi. So it is theoritically possible? Of course this means re-writing the EEC code all together. Will it work?
#49
Originally Posted by Terran
I'm not out to sacrifice performance either. I'm out to change that ideal that it's OK to be a gas hog. The more fuel we consume as a whole, the higher the prices rise, this stuff isn't going to be around forever. The question is, when is the 302 most efffcient? At WOT? What RPM is the 302 ment for? Because then i could focus on reaching WOT quicker.
Those GT-500 front ends from US Body look nice. Except i don't know how badly they'd affect my safety in a crash.
#50
#51
#54
Originally Posted by rebel_ford4x4
in my opinion its a waste of time, keep these old fords as close to original as possible.
my 79 f150 with a 460 on 35's ( in my gallery) is a gas hog and my daily driver im not complaining about gas mileage. if i cared id buy a stupid 4 cylinder, i wanted it cuz its a good ol truck, i cant stand new trucks, im tired of seeing all these same new trucks running around which everyone thinks is so cool when everyone and their cousin has one just like it. i didnt buy mine for gas mileage, i bought it cause you cant beat the feel of driving an old truck and being able to do most repairs in your own driveway.
i just dont see after all the time and money it will take to put into it how it will be worth it in the end.
I bought my 79 Bronco to wheel and play with.
I wouldn't want to drive anything else other than that or my 77 F-100 that I use as a DD( this is my good gas mileage truck, I didn't want any 4 cyl.)
#55
I hope you make it Terran. It is definitely a sightly goal for yourself. I think you could do it.
My 73 f100 with a 400 gets about 16-18 mpg highway. I could probably push at least 20 or more if I had a tonneu cover and tweaked the 400 just right. Gotta love the 2V and that ol' motorcraft 2100 2bbl.
And for those of you who will ask... No I have no idea what gears are in her. I just got the truck about 2 months ago.
"Weight of foot - distance to floorboard + cubic inches = bad gas mileage no matter how you put it"
__________________
1973 F-100 Ranger
w/ '79 F-150 Ranger XLT cab and decals
400 2-v
automatic trans
power steering
__________________
1973 F-100 Ranger
400 2-v
automatic trans
power steering
#56
Originally Posted by MBBFord
Amen to everything you said.
#58
Originally Posted by 76supercab2
12-14mpg is possible. I'm pulling that down right now with a 390, 4BBL, C6, 3.00 open rear gears in a supercab F-150.
#60
Speaking of rear gears, i have a "06" right now meaning i have a 2.75 in the rear. Somebody told me swapping to 3.75 would make a pretty big improvement.
The only reason I'm not shooting for a higher gear than 3.55 is because I also have to tow a heavy load. I also have a 460 which is pushing about twice the HP you are.
PS. if your close to Cape Cod, Mass. I'll lend you a 3.00 to try if your running a 9 inch. I have one in my 70 ragtop.
