most common problems
It's time to retire my 1994 F150, 4.9L, 5 speed. The engine is still going strong with 300k, but the body etc, aren't doing as well. Besides, I'd like a truck with A/C and auto transmission.
So, staying with an F150 - I'm looking at anything in the 1998-2001 range, 2wd is fine, I don't need a big engine - 6 cylinder is fine, better gas mileage, etc.
Can anyone summarize which F150 engine, year, model I should look for, or perhaps stay away from, based on known problems.
I can summarize the '94 F150 - 4.9 Inline 6 - awesome engine. Rear fenders on 94 F150 rust out early, oil pan rusts through, rear leaf-spring brackets rust out , stuff like that.. (two words - road salt)
Dang, you have a lot of rusting going on. Apparently you dont need a lot of power but I would stay away from the 4.2, cause they are way underpowered for a full size truck. The 4.6 may suit you better. The 4.6 is underpowered for a v-8 but in a full size truck does as good as a v-6 and dont waste a whole lot of gas.
97-99 stay away from the V6, they had problems w/ the head gaskets. Gasket would fail and coolant would get in the cylinder and hydrolock the motor. The V8s are pretty reliable, a few have had spark plug blowout. Ford didn't put enough threads in the heads. It's not common but it does happen.
The only sensor I've had go out was an O2 sensor. No big deal.
One of the more common problems are the ball joints. Some guys have had to replace them as early as 30k. Mine made it to 103k. Not quite gone but I was putting some drop springs in so I went ahead replaced them.
When you get one make sure it has been in for the cruise control recall. This is the latest recall. The cruise deactivation switch is in direct contact w/ brake fluid. The brake fluid eventually eats thru the plastic in the switch. Since the switch has constant power it can cause a fire. Mine failed but the fuse blew.
make sure if you test drive a v6 (4.2)- make sure you floor it and make sure it doesn't "miss"- i have had a problem with my truck "missing" under acceleration- and still can't find the problem- heard a couple people having this problem with the v6. other than that the 4.2 v6 is a good engine. other than clutch going out and a minor vac. problem no major problems.
I bought my 97 Lariat with a 4.6 auto tranny just over 4 years ago. In the 4 years I have had the truck, I have had the front brakes along with the lower ball joints replaced and that was at 120k miles. It now has over 150k miles and the only thing that has happened is the check engine light came on and has since gone off. It would come on then go off after a random time period or after I filled the fuel tank. It hasn't been on now in over 6 months.
It gets an average of 17 to 18 mpg running around town and 21 to 23 on the highway.
The truck runs as good now as it did when I bought it.
97 Supercab 4.6
I have had my SC 4x4 since it was new. Very few problems, no sensor problems ever in 104,000 miles. Gets 11mpg in town and about 17 on the highway. I have kept track of every fill and the lowest is 8.6 & the highest 23mpg.
Ball joints were replaced about 30,000 and are due again. Ford dealer wants $1800 to do the front end and replace the rotors and pads. Ouch!! Have to get out the toolbox for that kind of money.
Dave
Dave
