.025 flux core wire by mail? - Ford Truck Enthusiasts Forums
Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Old 09-21-2005, 12:38 PM
ferguson777's Avatar
ferguson777 ferguson777 is offline
ferguson777 is gaining momentum as a positive member of FTE.
Can't seem to find anyone that carries .025 flux core mig wire.
Can anyone direct me to a mail-order site that does?
(Even Harbour Frieght doesn't seem to carry .025 flux core)
Thanks,
Old 09-21-2005, 12:57 PM
berkad's Avatar
berkad berkad is offline
berkad has a good reputation on FTE.berkad has a good reputation on FTE.berkad has a good reputation on FTE.
I think, but don't quote me, that the smallest flux core will come is .030. MSC industrail supply has that.
http://www1.mscdirect.com/cgi/nnsrhm
Old 09-21-2005, 01:00 PM
Putt's Avatar
Putt Putt is offline
Putt is gaining momentum as a positive member of FTE.
I don't recall ever seeing .025 flux core, only .030 and larger. The .025 is solid wire for use with shielding gas.
Old 09-21-2005, 04:58 PM
It's o.k., I found it (I think) at Northern Tool.
Hobart Mild .024 Welding Wire. (Flux Core) Hobart# H305401-R19
Northern Tool part# 164897.
$11.99 USD for a 2 lb. roll
(mean't for body panels)
Thanks anyway
Old 09-21-2005, 05:09 PM
berkad's Avatar
I hope the picture is not of the wire. Description on Northerns webpage says flux but picture is if solid wire.
Description of that wire from my welder supply house webpage:
Hobart H305401-R19 .024" 2 lb. Spool of Solid Carbon-Steel Welding Wire
Old 09-21-2005, 07:39 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Nope, that solid wire, says so right on the spool. Most little mig welders have two sides to the rollers, you use one side for the small stuff like the .025", and the other for the .035". Many different welders use the same contact tips as the Lincolns at Home Depot, the design of their torch came from Tweco. My 20+ year old Snap on machine uses the same tips.
It's really hard to weld thin sheet metal with the flux-core wire, since you have to start and stop frequently. You don't want to build too much heat in one spot, and you want to see the color of the puddle, so you don't burn through and have a big glob of hot steel land on you.
Old 09-21-2005, 09:55 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
The people that make catalogs never cease to amaze me.
Old 09-22-2005, 10:50 AM
Northern have to contact me with shipping options, so I'll take that opportunity to confirm whether it's flux core or not.
In the meantime, anyone got a definite part number for .024 - .025 FLUX CORE mig wire from any mfgr/supplier?
Old 09-22-2005, 12:23 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
Doing a Yahoo search comes back empty for .024 or .025 flux wire. I have never heard of it and I have been welding for 5 years and used a bunch of solid and flux core wire from NAPA, Northern Tools, and my local supplier. I have never seen it in any catalog.
Just because the manual or instructions, probably translated wrong from Chinese, says you need it, does not mean it is correct.
What machine do you own that says it is required?
Old 09-22-2005, 12:41 PM
Rebo,
"because the manual or instructions, probably translated wrong from Chinese, says you need it, does not mean it is correct.
What machine do you own that says it is required?"
It's not really a case of "...says I need it....."
I have a cheap little Cdn Tire branded (probably Lincoln) flux core welder that I've been using .035 wire with to make frame modifications, engine mounts, etc for my 54 F100 rod. I now want to do some body work mods - welding patch panels, etc. Most welding books, etc say you need a smaller guage wire like .025 for the thinner sheet metal and they also recommend a softer wire that is apparently easier to grind, hence my query.
So.........?
Old 09-22-2005, 11:41 PM
Ford_Six's Avatar
Do a search on Yahoo for "Welding wire for bodywork". The first return is a guy crying about how crappy of a job the flux core did on his car. You need to see the puddle, and you can't with flux core.
For the second part of this, I weant back and re-read the ad. It's poorly written, I think an untrained blind monkey hitting a typewrite with a rock would come up with a better description, but here's my interpretation:
They are generally saying use flux core wire without gas, use solid wire with gas. That's about it, they aren't saying that is flux core wire. I don't think it is possible to have flux core stuff that small, as it is the .035 flux core I run every now and then breaks if you bend it any tighter than the spool, so I would think that any smaller would be too brittle to work.
Old 09-23-2005, 09:03 AM
OSin86 OSin86 is offline
OSin86 is starting off with a positive reputation.
I've got a Hobart 135 and run a lot of flux core. I have no idea what they are talking about with not being able to see the puddle. I can see it fine when I'm welding. My Hobart came with the bottle set up so when I do body panels I run it like a MIG to avoid any splatter. You can do body panels with a .030 flux core and do a good job but the splatter is annoying. I've never seen .025 flux core either and I think the guys are right, you probably won't find it.
Old 09-23-2005, 06:55 PM
Thanks for the input guys. I guess I'll give the .030 a try....
Old 09-24-2005, 03:30 AM
Yes, I use .024 with gas for body panels and where it is really useful is welding exhaust tubing so you do not burn thrrough the thin metal or totally distort the flange you are welding on to the pipe.
Solid core is much cheaper in the long run over flux if you do a lot of welding.
You can do sheet metal with flux, it is just messier in general, especially the splatter and clean up. For working on the interior of the car, the solid core is much better.
I go here for expert welding advice:
http://www.hobartwelders.com/
0.025 ESAB Spoolarc Easy Grind wire Dr G 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 08-23-2016 09:41 PM
welding Leroy Unlisted Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 30 05-20-2016 04:44 AM
Body work repair - welding Kierobi 1973 - 1979 F-100 & Larger F-Series Trucks 16 10-31-2015 10:26 AM
.025 wire on firewall? pics jrockdiddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 11-21-2014 03:43 PM
welding advice foofees 1973 - 1979 F-100 & Larger F-Series Trucks 9 09-11-2014 10:59 PM
Tags
025, 030, body, core, exhaust, flux, lincoln, metal, mig, panels, patch, pipe, sheet, weld, welding, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
